First post, by Magic
Hi.
I spent £2.50 on a boxed copy of this and have been trying to get it to work with mixed success.
I installed it but it didn't work so I tried DosBox, still didn't work. Never was able to see the error message either. So I copied over the CD files to the directory and set it Auto for all of the memory options in the Properties of Shadow.exe. The game now runs, but is -very- slow and I can't even skip the intro sequence.
Any ideas?
Update: I tried changing the options on the Memory to high values instead of Auto and I can at least skip the introduction. However, when the game loads it's again -very- slow. 🙁
-Magic
www.samods.com - Mods by modders.
Reply 1 of 2, by El nostalgico
You should start it with DosBOX, not with windows. Ok and what kind of Ws do you have??? XP, 2000, or others????
I actualy play the game with DosBOX amd its working absolutly perfect (v0.63).
So you have to specifying zour quest.
