error message
First post, by oldtimer
:blah: I had anew motherboard installed same cpu 3.46 Celeron 2gb ram. os is xp sp3. vidio card is nvidia ge force9500 gt. sound card is realtek hp. I get the same error message every time. 16 bit ms dos subsystem c:\windows\system32\cmd.exe {cs:0000 ip:0077 op:F03705 0e02. I played the games before. now will not work. what can i do.
i downloaded the newest dosbox and it still gives me the same error. Oldtimer
Reply 1 of 1, by Kippesoep
That can't possibly give you the same error message when being run through DOSBox, as the 16bit DOS subsystem that cmd.exe has is not used at all by DOSBox. The text you list also isn't the actual error message, but the extra information, which is only partly useful (though having cs=0000 is an indication of at least the type of error). Also... What game are you trying to run?
My site: Ramblings on mostly tech stuff.
