First post, by CrisGer
- Member
Finally i am getting a chance to play thru Nomad Soul, and what fun it is.. and so interesting to see the fully animated characters and faces of the people..they actually have a full range of expressions..and the story is fun too....
the trick in case you have had trouble running it on XP is to make dummy files for the three opening videos...just make empty text files with the same name and then put on the extension and pop em into the game folder and it should run fine. These vids have a format that is not compatible with XP...and it stops even a decent and full install from authentic disks from running. I finally found the resources and info to get it running.
and look...a really working mirror! one of the few i have ever seen in any game 😀
and the world is beautifully individualistic, the art style is remarkable and fun to explore...
i have put together a patch pack for this game ......you will need to own an authentic actual copy of the game to use this patch and to run the game you will need an authentic disk in the drive...usually number 2 of of the disk set.
the patch pack also has some optional mods that allow you to change bodies, and adjust some of the skins. Plus SAVE games and some other goodies.
Here is the patch for XP ...including SP3 Pro
http://www.filefront.com/17381088/Omikiron Patch Pack 3.0.rar
A truly remarkable RPG and a wonderful adventure. Great voicing and music!
You will have to own actual and authentic game disks for this to work and i have had to play with the correct disk in the drive..usually number 2.
Admin
3D Worlds and Game Developers Group Linkedin
http://3dworldandgamedevelopers.blogspot.com/
