First post, by VGCodemaster
I am trying to get a lot of windows 3.1 games to run through DosBox but to no avail. (Games that will not run in windows xp compatability mode and many don't like windows 95 either)
I can boot up into windows 3.1.1 for workgroups fine, I can browse the CD and run the setup and install the games. Then when I click the link I almost always get a message about not being able to find the cd even though I can browse the cd's files!
This happens with Lunicus and Meet Mediaband so far.
Also I seem to get frequent PROGMAN kernl crashes.
Anyone have any ideas?
Reply 1 of 4, by Hazekel
I don't know about that, but I always copy the entire CD to a subfolder under your DOSBOX - WINDOWS directory and then make sure when you load DOSBOX you identify that folder as the CD Drive ... e.g. "d: c:\DOSBOX\CD -t cdrom"
You may also need to add some other tags as well.
I run a few Windows 3.11 games, but not any with CDs so that is my best advice. Hope it helps.
Reply 2 of 4, by VGCodemaster
I tried exactly what you just said and I still get the message that it cannot find the cd rom for both of those games. Also, after the error if I click file and browse in windows 3.1 it's an automatic progman crash.
If I attempt to use browse to run the exe files directly it is also an automatic kernel crash as well.
Reply 4 of 4, by Gamecollector
Tested with Achtung: Spitfire - the game works only with IMGMOUNT command.
So, try to make cd-image and to use imgmount.
