First post, by retro games 100
I have just downloaded the demo for Quake 2, for some MiniGL 1.49 testing. I installed this game on Windows 95, but when I go to launch it, the display freezes before the running demo/game begins. When I try to launch the game demo, I see on the screen a "blank looking window" displayed in a low resolution (320x200 ?), with a large mouse hourglass cursor pointer on it. At this point, I have to press the reset button on my mobo because the game demo has frozen.
I am using a 3dfx Voodoo3 2000 AGP video card, with the last reference drivers released by 3dfx. For another test, I used the same hardware, but with a Windows 98 SE HDD. That all worked. So, there's something "odd" about my Windows 95 set up. Any ideas please people? Thanks a lot for any advice.
Edit: This is a bit strange. I just installed Quake 1 shareware version 1.06, in Windows 95. After it installed, it automatically attempted to run, and then froze. It seems to freeze at the time when the CD-ROM drive is being checked to see if there is an audio CD in the drive to play music.
Solved! I did: Control Panel -> System -> Device Manager -> CD-ROM -> Properties -> Settings.
I then unchecked the DMA option. I also unchecked "auto insert notification". I'm not sure if that makes any difference. I just decided to do this anyway! The PC rebooted, and both Quake and Quake 2 now work.
Reply 2 of 6, by retro games 100
DosFreak wrote:
damn must be an ancient cdrom
Sorry, I should have been clearer in my original post. I'm using a DVD-ROM reader, circa 2007. I wonder if the problem I encountered is chipset driver related? Something to do with VIA's 4-in-1 version 4.43 chipset driver. When I installed this chipset driver, it gave me the choice of using DMA, or not. I chose DMA, but I think I have read somewhere that this can cause compatibility problems with some hardware.
Reply 5 of 6, by Tetrium
Is the general hint to simply not use VIA's own drivers but to use the ones that came with Windows?
My retro rigs (old topic)
Report spammers here!
Reply 6 of 6, by retro games 100
I'm using Windows 95. The board's BIOS is date stamped 2000. IMO, I think the best approach is to follow VIA's release notes, and install their driver. I'm guessing that whatever driver is on the w95 CD, it might be too old.
