First post, by retro games 100
- l33t
Set up: 3dfx Voodoo5 + 1.04.00 driver. I am running Unreal in GLide mode, 800x600 with 4x AA. When I begin Unreal, I walk right, over to the other side of the corridor. It takes 1 - 2 seconds to get there. If I turn around, and then look up, and then move the mouse a tiny bit, I can see the upper floor area, but it looks odd. The graphics look weird. Here's a way to explain this weirdness -
if you stand in front of a mirror, and you are also holding a small hand mirror, and this small hand mirror is pointing at the larger mirror, when you look at the reflection of this small hand mirror within the larger mirror, you can see a kind of "infinite recursive image" inside the image of the small hand mirror. I see this same "infinite recursive image" on the upper floor area in Unreal. Anyone else notice this phenomonen playing Unreal in GLide mode, using the same hardware and driver version?
