Aliens vs. Predator Gold
Getting old Windows games working.
Re: Aliens vs. Predator Gold
Postby Splinter » 2013-6-07 @ 20:17
Great job.
I simply wouldn't survive without unlimited saves.
Cheers mate!
http://www.compufixshop.com
FX8320 3.6Ghz-Asus ROG RX580 8Gb-Corsair Strafe RGB-Samsung 27" Curved FreeSync monitor
User avatar
Splinter
Postby Perth2008 » 2013-6-22 @ 05:27
Thought I'd share this, though I'm sure a few have tried this already.
If you have used sirlemonhead's great AVP Gold fix (aka AVPX, available here: http://homepage.eircom.net/~duncandsl/avp/) as I do you may have also wondered whether it would work with Mad_Max_RW's AVP Classic Redux 2.0.
Well I downloaded the two massive installation files (1.6 and 1.7GB each) which can be found at moddb, here: http://www.moddb.com/mods/aliens-versus-predator-classic-redux. As noted in the readme file, Mad_Max_RW's mod was made specifically for the re-release of AVP Gold on Steam and was not guaranteed to work with AVP Gold.
Well of course it doesn't work with AVP Gold out of the box but it DOES with sirlemonhead's AVPX! While it takes much longer to load each mission or skirmish map you will find much to enjoy and marvel at in Mad_Max_RW's visual enhancement. The map environments have had a major face-lift but best of all, to me, are the much improved character models, obviously using an order of magnitude or more polygons such that all characters look more natural and less angular.
Well worth a look ... but only after you have tried and played through the original using AVPX as that way you will have a sound basis of comparison. After a few hours of testing a number of maps only a couple of crashes/freezes were experienced but probably this is because it the Redux is not meant to be compatible with the non-Steam version. But it worked for me 95% of the time. ENJOY.
User avatar
Perth2008
Postby Perth2008 » 2013-6-22 @ 07:22
sirlemonhead wrote:Find your AvP config file (usually in C:\Users\YourUsernameHere\Documents\My Games\Aliens versus Predator\AliensVsPredator.cfg
Edit that and change the line
UnlimitedSaves = false
to
UnlimitedSaves = true
Ha, ha, ha ... if only I'd known about that simple fix! :exclamation:
Still playing as intended with limited lives cannot be beaten as a pure (undiluted) adrenalin rush. Perhaps now I can have a go at Director's Cut difficulty!
Planning to replay the whole game at some stage with the Mad_Max_RW graphical enhancement in due course. Surprised the files worked so readily in the standard C:\Program Files\Fox\Aliens versus Predator directory despite the disclaimer in the Redux version readme file.
User avatar
Perth2008
Postby sirlemonhead » 2013-6-22 @ 12:12
They used my source code to make the Steam release of AvP Classic 200 whatever so i'm not surprised it works :p
By the way, does anyone have any suggestions for a new name? AvPx wasn't anything I had put much thought into..probably me naming the xbox port I did, or just trying to differentiate from avp.exe
It's not something that has to remain as is so i'm open to suggestions :)
User avatar
sirlemonhead
Postby Perth2008 » 2013-6-22 @ 14:42
G'day sirlemonhead
Well I've dropped a few references to your work on AvPx and sound fixes around a few gaming sites so sticking with the current name works for me.
It's your creation so call it whatever you like ... :happy: But whatever name you give it, it would be helpful to include the version number and/or date in the file properties of the installation file and AvP.exe.
Hmmm, played a bit more using Redux mod and it is certainly more stable with the skirmish maps than in the campaign missions but there is some interesting work in the mod and well worth a look. :s-face:
Thanks again for making the AVP Gold playable!
User avatar
Perth2008
Postby sirlemonhead » 2013-6-22 @ 15:33
No problem. Let me know if there's anything else I can do (except multiplayer..that's sorta a work in progress when I can muster up the energy to look into it)
User avatar
sirlemonhead
Postby Valet2 » 2014-1-01 @ 23:07
Sorry for commenting before reading the previous messages, but here's my experience I want to share:
I'm very happy with steam's "Classic 2000" version! I've been playing for a week recently, and it was a blast from the past. No bugs at all (oh, maybe the game just once crashed)! No fps-drop! The music works, save/load works, no intro-videos looping sound. I had good time completing all levels on Director's Cut. The system is Win7-64 with GTX460.
On my laptop with Win7-32 & Intel GMA 4500M I have the gold edition which works fine - I have it there because I've been playing around with a level-editor (always wondered what's behind the ceiling where xenomorphs do appear). Also DEMO-versions (released in January 1999) work! Even with widescreen resolution!
But neither original nor gold edition works. Even with AvPx. But I think I've played it fine (without patches besides an updated bink-library) on WinXP after nVidia made a fix in their drivers sometime around 2009.
That's it! The "Classic 2000" version is great! If you want you can replace the ogg's with higher-quality files, and put older fmv's from the original game.
--- Old Habits Never Die ---
Valet2
Postby TELVM » 2014-1-12 @ 01:43
I prefer playing the original AvP on a PIII system, but the 2000 Classic has the advantage of easy recording on modern comps :happy: :
Tyrargo · Marine · Director's Cut · Suicide Run :lol:
Boy do I love this game, one of my all-time favourites. The pace is completely crazy and the bugs give you no respite :-D .
Let the air flow!
User avatar
TELVM
Postby Valet2 » 2014-1-12 @ 10:06
Valet2
Postby TELVM » 2014-1-13 @ 00:47
^ Yep, 'spearjump' has its uses :lol: :
Unfair Battle
But it's dancing with the bugs and taking acid baths where the fun is :-D .
Let the air flow!
User avatar
TELVM
Postby Valet2 » 2014-1-13 @ 08:49
Yeah, I did that too :) Also, there's an utility (works with Gold Edition fine) that allows you to play any character on any level! It was very interesting to know, that Alien Queen, for example, is hostile to Alien!
Add me on facebook.
Valet2
Postby NTxC » 2014-1-28 @ 02:52
Hello,
I just registered here to say: THANK YOU sirlemonhead for fixing this game. I'm a huge fan of it (since 2003 or so), I really really love it and I love your work. Thank you again for making it playable on Windows 7. It's nearly perfect.
You, sir, are a legend.
Regards
Patrick
NTxC
Postby sirlemonhead » 2014-1-28 @ 17:48
You're welcome. Let me know if you run into any issues and i'll try fix them.
User avatar
sirlemonhead
Postby Rekrul » 2014-1-29 @ 00:15
I haven't checked this thread in a while. I have a retail copy of AvP Gold. If I were to get a copy of the original, non-gold AvP, could I substitute the original briefing videos? I've heard that they were better than the ones used for the Gold version.
Rekrul
Postby Valet2 » 2014-1-29 @ 06:35
Rekrul wrote:I haven't checked this thread in a while. I have a retail copy of AvP Gold. If I were to get a copy of the original, non-gold AvP, could I substitute the original briefing videos? I've heard that they were better than the ones used for the Gold version.
Some of them are better, some - not. I've spent quite a few time comparing them. The Gold-version has 2 more videos in addition (featuring the Rebellion guys).
Valet2
Postby Kerr Avon » 2014-1-29 @ 14:46
Sirlemonhead, did you ever get around to updating the XBox port you did? If not, then please consider it, as there are still a few (few but loyal) XBox fans who'd love to see an updated version of AvP on the ol' XBox. But if you don't have the time then thanks for the great work you've already done on it, it really is appreciated.
Kerr Avon
Postby sirlemonhead » 2014-1-29 @ 21:23
I thought of the xbox version the other day actually. Last time I ran the code on the xbox, I wasn't getting any rendering anymore so I think it's either horribly broken or there's something simple. If there's still people interested though, I should make an effort to get it working again.
I like to think that at least I put the source code up online, which is something most xbox ports don't have available :)
User avatar
sirlemonhead
Postby Kerr Avon » 2014-1-31 @ 14:25
sirlemonhead wrote:I thought of the xbox version the other day actually. Last time I ran the code on the xbox, I wasn't getting any rendering anymore so I think it's either horribly broken or there's something simple. If there's still people interested though, I should make an effort to get it working again.
Please do, I know it's still popular, and it would be great to see an update, especially as sadly there is so little homebrew activity nowadays. At the moment, it's only Doom (in the form of Odamex), XBMC, and MAME that have been updated recently, and an occasional (but fairly frequent) update to Mabmad's emulators, so the XBox homebrew scene isn't dead, but it is slow, and almost entirely emulation based now. The fact that the XBox-scene's forums have been down for a while doesn't help either. But a new XBox version of the only really good AvP game ever made (I'm not including the Jaguar game in that, as I've not played it so I can't judge if it's good or bad) would be a great gift to us loyal XBox fans.
Actually, AvP 2 was quite good too, I think, but nowhere near as good as the original. But starting with AvP 2, every AvP game seems to have been inferior to the one before it. AvP > AvP 2 > AvP (2010) > Aliens: Colonial Marines.
I'm so glad it's the 1999 Rebellion game you ported to the XBox.
Yes, I seem to remember reading that (though sadly as a non-coder it wouldn't be useful to me), but no one seems to have picked it up and worked on it, or at least if they did they didn't release an updated binary. I assume AvP was/is very complex so it would have put off many potential coders, sadly.
Kerr Avon
Postby TELVM » 2014-2-01 @ 08:58
Kerr Avon wrote:... Actually, AvP 2 was quite good too, I think, but nowhere near as good as the original. But starting with AvP 2, every AvP game seems to have been inferior to the one before it. AvP > AvP 2 > AvP (2010) > Aliens: Colonial Marines ...
Wholly agreed! The crazy dynamicity of the '99 original remains unsurpassed.
Let the air flow!
User avatar
TELVM
Postby S_A_K_U_L » 2014-3-25 @ 15:21
Is there any chance that multiplayer via LAN will work in near future releases? I would pay heavy money for just that :B
S_A_K_U_L
Previous
Return to Windows
Who is online
Users browsing this forum: No registered users and 2 guests
cron
