First post, by SKARDAVNELNATE
Click on the shortcut. Passes the DVD check. Screen flashes briefly and the mouse pointer changes location. Then a dialog box comes up saying "jericho.exe has encountered a problem and needs to close" and prompts me to tell Microsoft about it.
I've seen posts suggesting there might an issue with PhysX so I removed the Nvidia one and installed the version supplied on the disc. No change.
Can someone check if they have this problem?
Reply 1 of 5, by BigBodZod
I did install the Steam version DEMO on my Windows 7 - x64-bit machine and it seemed to run fine.
Not sure if I had to do any compatibility settings or not, maybe there is a disc based copy protection scheme causing a malfunction ???
If I ever get the full version I will let you know, but for sure I can get the demo working just fine.
No matter where you go, there you are...
Reply 2 of 5, by Davros
runs fine for me in win7x64 with gtx260 and 6950 (fine with xp as well )
try a nocd
anything in event manager
theres a log file in the jericho folder
Reply 3 of 5, by SKARDAVNELNATE
My system is Windows XP with Nvidia 8800gt graphics. Video driver 285.58 version.
Tried using Fairlight and Vitality No-DVD fixes. Problem persists.
Event viewer has plenty of Application Errors.
Faulting application jericho.exe, version 1.0.0.1, faulting module kernel32.dll, version 5.1.2600.5781, fault address 0x00012afb.
The log.html is equally unhelpful.
-= Game log file =- (Wednesday, August 08, 2007 19:23:51) […]
-= Game log file =-
Version: 0.24
(c) Mercury Steam Entertainment
Log closed.
Reply 5 of 5, by SKARDAVNELNATE
Everything is updated to the latest version.
Actually this is strange. I spent the past day setting up a 2nd main drive. This one I didn't install any extra software on. Just drivers for the hardware and updating Windows. On that drive Jericho works. I must have something installed that's causing it to crash on the 1st drive.
