First post, by bluesurfdream
however i did manage to install theme hospital from cd in/over dosbox it was hard but somehow it worked to install it
(always got error messages couse it was not able to write / even it were mounted)
if there is any help which it makes it easier to install and to understand if and how installation works in/over dosbox tell me plz this is one of the main point in this topic by any terms of logic tell it plz
(there was a further topic about theme hospital were the guy wasnt able to find "\" bit its in german keyboard layout on "<"">" i think with pressed "alt"
so the next problem
i bought a new version of theme hospital 1 - and it requieres a cd to play
when i mount the cdrom and i st
no cd cracks doesnt work i get the same problem with the other themehospital topic ..win32 needed
how to tell dosbox like a regestry it needs to play the cd - when i start the setup on cd under/in dosbox - its not knowing - the game is allready installed - becouse there is no regestry
( i try to run it under win7 64bit) plz reaplay if your able )
