First post, by Veggieleezy
I'm fairly new to the whole emulator/Dosbox process, so I'll try and be as specific as possible with my problem.
I'm currently trying to play some games that I found at Goodwill (Carmen Sandiego's ThinkQuick Challenge, Pajama Sam 1, Tonka Garage, and Where in Time is Carmen Sandiego, all original jewel case discs) on my computer (running Windows 7 Home Premium, 64-bit).
I've installed Dosbox and I think I've mounted everything properly. My e-drive is my disc drive, I've got a folder set up for the games to go into on my c-drive. I did the following steps to try playing one of the games. I put the disc in, opened Dosbox, and typed the following commands:
z:\>mount d e:\ -t cdrom
z:\>mount c c:\oldgames
z:\>d:\
d:\>
From here I tried to type setup but I got the error message "This program requires Microsoft Windows."
What do I need to do from here? Did I do something wrong? Am I missing something I need? If I need to download something, where do I put it? Bear in mind I'm still very much learning how to do this, so any help is appreciated.
