First post, by memsys
Hey guys i have a problem with Red alert 2 and Tiberian sun from the C&C first decade pack .
i can't play them
after tweaking the compatibility settings i get them to start , however the menus are broken i can see the main menu but when i click a button the menu graphics are not updated or garbled and i can't even see the Red alert 2 intro .
I have tried the 1.03 community patch to no avail
Any help would be much appreciated
EDIT : I forgot to mention that i use a laptop with an I5 M460 and a geforce GT335M runing win7 64-bit
I also discovered something odd when i took a screenshot the menu's did show up correctly on the screenshot but not on my monitor . This happens with both games.
Another strange thing is that with Red alert 2 when i click exit game it does show the confirmation menu with the tesla trooper in the background
^ the screenshot.
^ what i see on my screen.
Reply 1 of 3, by chinny22
Found this which has a list of common problems
http://blog.obelisk.ro/2010/09/resolution-fix … rt-2-yuris.html
I found C&C2/RA2 more trouble then the originals! also using a Win7 x64 Laptop.
In the end I tried installing in the virtual WinXP mode but got sick of the whole thing and installed it on my WinXP PC so cant be much more help
Reply 2 of 3, by memsys
And it works! And all i had to do was go into Intel graphics options , power management and pick maximum performance .
I can't believe how stupidly simple this fix is 🤣 .
Also Ra2 NEEDS v-sync on unless you like screen tearing .
Tiberian sun is still not running perfectly . When i click on an icon to build a building or unit the game slows down by quite a bit the same thing happen when the credit counter changes .
Thank you Chinny22
Reply 3 of 3, by jmrydholm
I had that issue with my R1 m11x Alienware, I manually set it to the Intel chip rather than the NVidia card. I haven't tried it out on my newer laptop, but I'll play around with it. I'll try whitelisting it in the Optimus drivers and see what kind of results I get. I did have Red Alert installed on the m11x for a time, but for some reason got frustrated with TS and put that on my XP rig, just like chinny22.
"The height of strategy, is to attack your opponent’s strategy” -Sun Tzu
“Make your fighting stance, your everyday stance and make your everyday stance, your fighting stance.” - Musashi
SET BLASTER = A220 I5 D1 T3 P330 E620 OMG WTF BBQ
