First post, by PhaytalError
- Member
Greetings all!
As of right now I have a tricked out non-stock Windows 98SE install, however games such as GTA3 require at least Windows 2000 to install, and I don't think KernelEX can "trick" it into installing. My "Classic Gaming Rig" specs meet the recommended requirements for the game, however im not just a Windows gamer im also a DOS gamer so I do have some concerns if I decide to use Windows 2000 [it's what I used to use "back in the day" but it's been forever ago so I don't remember if what im about to ask worked or not].
My question is this, if I installed DOS games and DOS drivers [SB16 stuff] on the same Windows 2000 HDD, and booted into DOS with a DOS boot floppy disk [created with either Win98SE or Windows 2000] will those games run properly complete with sound, etc?
Thanks in advance. 😀
DOS Gaming System: MS-DOS, AMD K6-III+ 400/ATZ@600Mhz, ASUS P5A v1.04 Motherboard, 32 MB RAM, 17" CRT monitor, Diamond Stealth 64 3000 4mb PCI, SB16 [CT1770], Roland MT-32 & Roland SC-55, 40GB Hard Drive, 3.5" Floppy Drive.
