Reply 40 of 46, by FeedingDragon
- Oldbie
wrote:If you really want to be thorough, the easiest way to verify burned data would probably be: -Create an ISO or BIN/CUE image with […]
-Create an ISO or BIN/CUE image with the files you want to burn
-Burn the ISO image (any worthy CD burning program can do this)
-Re-rip the ISO image from the burned disc
-Compare the ripped ISO image with the burned ISO image, using checksums, fc, or WinDiff.
This technique at least minimizes the number of operations involved.
The real problem with that is that I do, regularly, create multi-format CDs and ISO cannot handle those 🙁 I generally use .bin .cue for images for that reason. I also generally don't create the image and then burn it to CD, I have yet to find a .bin .cue editor/creator. Of course, I've never really looked for one. I imagine that if I could create/edit the .bin .cue files to manually add files to them on the fly (creating the image,) your method would work just great. The .cue file is just a text file, so I could check that manually (headers and comments could be different.) As long as both .bin files are formatted the same way, all is good.
Feeding Dragon
