Actua Tennis
First post, by Bladeforce
Hi, I am getting an error "API error" when starting Actua Tennis on Windows 7 x64. Has anyone got this running especially in 3dfx mode if possible, Thanks 😀
Reply 3 of 29, by [Zeus]
Did you run PatchInstall.bat and At.reg after replacing all files?
If so, reinstall the game and then create bat file with this command:
regedit /E myreg.reg "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis"
Execute bat file and post myreg.reg content here.
Reply 4 of 29, by Bladeforce
I have reinstalled the game and made the batch file and run it.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis]
"DisplayName"="Actua Tennis"
"ModifyPath"=".\\SETUP.EXE"
"InstallLocation"=".\\"
"InstallSource"=".\\"
"DisplayVersion"="1.00"
"VersionMajor"=dword:00000001
"VersionMinor"=dword:00000000
"Publisher"="Gremlin Interactive"
"ProductId"="TennisCode"
"RegCompany"="."
"RegOwner"="."
"HelpTelephone"="(+44) (0114) 279 9020"
"HelpLink"=".\\readme.txt"
"URLUpdateInfo"="http://www.gremlin.co.uk"
"URLInfoAbout"="http://www.gremlin.co.uk"
"LanguageLetter"="E"
"Footprint"=dword:00000002
Was I correct in doing it before adding the patchinstall.bat and replacing the files?
Reply 5 of 29, by [Zeus]
Yes, don't use my patch (files, PatchInstall.bat or at.reg) before creating myreg.reg file.
Now do the same for a different reg key (if you used my patch already, reinstall the game again).
Create a bat file with this:
regedit /E myreg.reg "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis"
Post myreg.reg content.
Reply 6 of 29, by Bladeforce
Ok here is the result of both in one post
Using the first key [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis]
"RegCompany"="."
"RegOwner"="."
Using the second key HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis
[HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis]
"UninstallString"="C:\\Windows\\iun6002.exe \"F:\\Install\\Actua Tennis\\irunin.ini\""
"InstallSource"="D:\\"
This has both been done on a clean install without any patch applied
Hope this helps! 😀
Reply 7 of 29, by [Zeus]
1) Now click at.reg and make a reg file from:
Again, post the result here.
2) Click PatchInstall.bat and open "Uninstall or change a program" dialog window. Do you see "Actua Tennis Patch" entry there?
Reply 8 of 29, by Bladeforce
Here is my contents of the registry key you want before installing the patch
Yes i see an Actua Tennis and Actua Tennis Patch in my list of programs to uninstall
Reply 9 of 29, by [Zeus]
I know. Now I'm asking you to make a reg file after clicking at.reg from my patch for
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Actua Tennis.
Reply 10 of 29, by Bladeforce
The contents after installing your patch
"RegCompany"="."
"RegOwner"="."
Reply 16 of 29, by Bladeforce
Tried Tennis2.exe same error as before
"ExUpdatePalette: Generating Look-Up"
Same error when running in windows 95 compatibility mode too
Reply 18 of 29, by Davros
could that error indicate the game needs support for palleted textures ?
ps: what gfx card do you have ?
amd check this:
http://groups.google.com/group/comp.sys.ibm.p … c1%3Ftvc%3D1%26
does it support glide ? glide wrapper
Reply 19 of 29, by Bladeforce
Thanks, Davros. I have no clue about the palleted textures I am not that technically gifted 😀
Yes the game runs on a 32bit platform with nglide but not on my Windows 7 x64
My card is A Nvidia 550 ti gfxcard
