First post, by Bladeforce
- Member
Hi, may I ask if anyone has the knowledge on why this 3dfx exe (f1win) won't work at all
Crashes out with an error
"The instruction at 77868da9 referenced memory at 00000014. The memory could not be written. Click on OK to terminate the application"
ntdll.dll is causing the crap out in the dropdown box error
The D3D exe runs with the act fix but crashes out with a ddraw.dll error when starting a race or going back to the menu after the demo mode
Windows 7 x64
edit I can start grand prix mode in d3d mode but it crashes when finishing the level and goes back to the menu. Selecting Aracde mode i can set everything up but it crashes before starting level
