First post, by Overstolz
Hi all !
i got a version of battle arena toshinden.
i really dont know if is the right board to ask, but ill just try 😀
at the setup there are 3 options
Setup Sound Card
Setup Connection
Misc Options
since im not experienced with those old DOS programms ill search help on this board 😀
Thanks for all help
Reply 1 of 5, by Gamecollector
You have the tsd.cfg file in the installer directory, so - the setup think the game is already installed.
By the way - looks like you don't use original cd, because you never find this file on cd.
Reply 2 of 5, by Overstolz
thats true i dont got the CD i just got this programm as a file 😉
btw it does do a normal setup now since i delete those TSD files 😀
now does the game tell me error message when ill try to play it
"Error running TSD:EXE
do i need to run it with dosbox?
thanks for answer btw !!!
Reply 3 of 5, by Jorpho
If you are deleting random files, the game will probably not function correctly.
You should install the game from its original CD, or ask the people at whatever site that you downloaded the game from. There is no telling whether all of the game's files are intact, and little point in trying to solve the problem without knowing that much.
Reply 4 of 5, by vetz
Overstolz, you are probably not aware, but support for such downloaded material is not allowed here on Vogons (site rules). Just giving you a heads up since this thread will probably be closed by a moderator. I'm trying to say it in a nice way as some other users will not.
Reply 5 of 5, by Overstolz
no problems anymore it was just a safe copy for a friend so we can play online
but i fixed this problem cause i searched about 2 hours my old cd´s 😁
now i installed it the original way and now i have to play thanks for helps !!!
