The aforementioned "King's Quest Collection (2006)" download will work with the version you have. They probably just included "Vista" on the box in subsequent reprints.
snowflake wrote:Now it is saying: The version of tis file is not compatible with the version of Windows you're running. Check your computer's system information t see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.............. WTF!!!! I have done everything right.
Evidently not.
What, exactly, are you running?
Also, please stop making multiple posts. If you need to add something to a post you just made, you can use the Edit button in the upper-right corner of your post. (It is kind of tiny and looks a little like the letter Q.)
