Well, uninstalling Avast didn't help.
DosFreak wrote:There was another post on these forums with the same issue who said Logitech interferred with installshield.
Wow, you almost hit the nail on its head, I closed all Logitech programs but the problem remained, then I closed FanaLED's, a program to display gearindicators on steeringwheels, and... my firewall gave me a message that SETUP.EXE wanted clearance (it didn't ask me that before) and NFS Porsche 2000 installshield runs.
yaaaaaaaaaaay 😀
Thanks man, without your hint I never would have guessed that such a program might have caused it. 😀
Davros wrote:It could be your system (does avast have a disable option? avg does)
It was I while ago and I cant remember what I did if anythi […]
It was I while ago and I cant remember what I did if anything but I did install nfs 4 and expendable in win7 x64
ps: installing expendable to c:\games\expendable will make things easie, also run as admin and with the shortcut change the target to read
go.exe -nocputest
ps: for nfs 4
I may of had to install the Stock & Expansion pack 4.0
http://www.nfscars.net/forum/showthread.php?p=663495
worth a read
http://www.nfscars.net/forum/showthread.php?t=8413
Avast does have a close all services option, but it still remains active somewhere, to be able to play Raceroom I had to uninstall Avast and do all kind of tricks.
I will check this out, thank you so much. 😀
