Reply 40 of 59, by VirtuaIceMan
Videos are fine for me, but I did install an Ligos Indeo 5 video video pack from somewhere (think it came with another game)
Reply 42 of 59, by teleguy
I ended up using WineD3D.
http://sourceforge.net/projects/wined3d4win/
That fixed all my problems and I can now run the game at full resolution and without flickering. FPS were reduced by ~50% according to the integrated benchmark.
Reply 43 of 59, by Marduk
Hey Guys,
I've manage to run Shadows of the Empire using DxWnd, but i have a little problem with Z-Buffer i suppose.
Look at attached screenshots. I can see through walls and other objects. Any suggestions in what im doing wrong?
Reply 45 of 59, by BuckoA51
I can run this game half a dozen times and get a different result each time. Sometimes it's too fast, sometimes it's too slow, sometimes it locks up, sometimes crashes to desktop.
It's Star Wars Racer all over again, LucasArts sure had some special talent for wonky PC code 🤣
play-old-pc-games.com
Reply 46 of 59, by VirtuaIceMan
There's another fix guide over here: http://www.play-old-pc-games.com/2015/02/10/w … shadows-empire/
Incidentally I find the DirectDraw fix/ACT fix here http://www.blitzbasic.com/Community/post.php? … 77&post=1202630 gets rid of any borders, but if you use > 60hz refresh rate it'll run way too fast! I can swap between 60hz - 120hz - 144hz on my monitor, which is handy!
Reply 47 of 59, by Jorpho
Remember how Indiana Jones and the Infernal Machine wouldn't run properly unless you started Windows Media Player first for some strange reason? That doesn't make any difference here, does it?
Reply 48 of 59, by VirtuaIceMan
My weirdest fix on XP was to run DXDiag to prevent Daytona USA and Sega Rally Championship from having crazy normal/fast/normal/fast framerates. No idea how that helped!
Reply 49 of 59, by filipetolhuizen
That also worked for me with Starsky & Hutch.
Reply 50 of 59, by VirtuaIceMan
On Win8.1 use ACT fixes:
ForceSimpleWindow
NoGDIHWAcceleration
This will improve framerate, though over 60fps = too fast in-game!
Reply 51 of 59, by Avoozl
I apologize for resurrecting an old thread but I registered because I need help with a problem I have with this game if anyone can please help me with it.
I got the game working and without music, but when I add the files from the sote_fix.zip posted here my game no longer starts with the new shadows.exe and my launcher just freezes when I press the button to start the game, the shadows.exe is running in the background but the program doesn't appear nor open, is there anything I can do to fix this? Any help would be greatly appreciated.
I am also on Doomworld.
Reply 52 of 59, by teleguy
Sounds like you're on Windows 10?
The original Winm0.dll is not compatible with Windows 10. Someone made this fixed one http://1drv.ms/1Rn0o8z .
    winm0 sote working mingw.7z
    102.47 KiB
    129 downloads
    attached in case the link goes dead
Reply 53 of 59, by Avoozl
Yes I'm on Windows 10 but with the fix you linked me I got it working and with the music playing, thank you so much. 😀
The only remaining problem which I have always had before and after the fix however are the window borders showing with a pixel length of transparency around it on the outside while in fullscreen mode, but I don't even know how to fix that.
Reply 56 of 59, by borgrail
Hi,
Well I tried the fix but trying to to run it on Windows XP SP3 was not a pleasant experience, videos corrupted, menus don't work properly, gameplay very slow. So I'll stick to using it with Voodoo3. It's the only game I have that needs it.
Reply 57 of 59, by Bladeforce
Just popping in to say a lot of these problems DO NOT exist in WINE
https://appdb.winehq.org/objectManager.php?sC … rsion&iId=12725
More options to play these the old games the better
Reply 58 of 59, by Sobek
Just wanted to say, after I stumbled upon this thread I just HAD to give this a go... I had SotE on my N64 and it was one of my favourite games ever... I also still have my original copy for PC but sadly I never actually had a computer good enough or stable enough to play it back then. That being said, honestly, this was even easier to get working than Ep1 racer was (and that was remarkably easy). I just installed it, used the SotE fix, copied over my WineD3D files from my Ep1 Racer install (because for some reason the ones included with SotE fix do not work at all, the game can't even load), and it was perfect. Did the audio file conversion, slapped on a whole lot of AA and AF, turned on vsync and that was that... the game runs 100% flawlessly. It's exciting to finally be able to play it the way it was intended and not the gimped N64 version!! Win 7 x64 here by the way.
Reply 59 of 59, by Ace
I had a hell of a hard time getting the game working properly on Windows 10 64-bit, but in the end, this is what I've done:
-Since the game won't install on a 64-bit version of Windows with its stock installer, I used that custom one from this site: http://www.play-old-pc-games.com/2015/02/10/w … shadows-empire/
-In order for the game to display properly on my Radeon R7 360 (same with my GeForce GTX570), I used dgVoodoo 2 (the latest version is ideal as it has proper aspect ratio correction, which is the only way to get a proper 4:3 image with an AMD graphics card)
-As the included WINM0.DLL doesn't work with Windows 10, I used the modified one from earlier in the thread (strangely, it causes all my other games to crash), but also hex-edited the game's EXE to use the original WINMM.DLL name, after which I proceeded to convert the music to OGG format (is there a replacement WINMM.DLL that works with WAV files instead and doesn't pull a fit on Windows 10? I really don't like using compressed audio formats with CDDA)
-I found that Shadows of the Empire runs too fast when its framerate exceeds 30FPS, so I suggest setting a framerate limiter to 30FPS for this game (easier to do on AMD cards, in my experience)
Creator of The Many Sounds of:, a collection of various DOS games played using different sound cards.
