First post, by DracoNihil
- Oldbie
I had the silly idea to see if Hellbender's multiplayer actually worked and when I was trying it with my boyfriend I noticed that... it is VERY VERY laggy looking.
Sure you look like you're moving smoothly but on the other persons side you move at a rate comparable to 5 FPS.
has anyone else tried this before (preferably on old machines) and had this happen? Did this also happen in Terminal Velocity?
― Κυνικός Δράκων
