First post, by jspyder
Does anyone know an effective way to get Atari Anniversary Edition to work properly with Windows 7 Pro 64-bit?
I can get it to install, get the main menus and click on the game, but as soon as I move the mouse to start the game - or hit the appropriate key - the screen goes completely black. I can ESC to exit the game, and I've tried all of the usual things, including compatibility mode. Nothing so far has worked.
Using a Virtual PC is also an option, but one I'd like to pursue only if everything else fails. (I still can't get some games to run full-screen in VPC ... )
Relevant info: I have a dual-monitor system. The primary monitor is on a GeForce 9400GT (PCI-E), and the secondary monitor is on a GeForce 6600 (also PCI-E) with recent drivers. (Other specs will be provided on request, but I suspect this is a video card/driver issue.)
