First post, by Cloudschatze
I recently built a Windows 95 "gaming" system, and then ended-up having to upgrade to Windows 98SE to gain use of a USB-connected peripheral. One irritating "feature" of the upgrade is that, after the system boots into windows, I get a "working-in-background" mouse cursor for 3-5 seconds, after everything else has finished loading. I really should just look away for those seconds - stare at my shoes, the wall, the ceiling - but no, principle dictates that this must be resolved somehow.
Through use of the selective startup features of MSCONFIG, I determined that this pause is due to the loading of the SysTray executable. Given that the only startup service I had running in the system tray was SNDVOL32.EXE, I changed the option for having it load, thereby leaving just the clock. The startup "pause" persisted. I hid the clock. The startup "pause" yet persisted.
With no services loading at startup into the system tray at that point, what on earth could it possibly be doing in the background? Thankfully, there is one related registry key, containing a single hexadecimal value - with no description regarding its usage. Thanks, Microsoft!
Popular opinion on the subject suggests that SysTray.exe is absolutely essential, and must not be disabled or excluded from startup. Well, I did just that. The sun still rose this morning, the pause has been eliminated, and the system still functions. Applications also continue to run/display in the System Tray after being manually started. As far as I can tell, the only detrimental effect is that any Windows-related, "display icon in the taskbar" services (such as the aforementioned volume control) will not run in the system tray. Horror.
Or, is there more to it, and I'm courting disaster here?
Reply 1 of 8, by NewRisingSun
I've got no such pause. Whatever causes it is not inherent in Systray, meaning that scenarios exist in which no pause occurs.
(The biggest time hog in my Win98SE system actually is SCANREGW.)
Reply 2 of 8, by Jorpho
Maybe defragmenting your hard drive will help?
Which key is that, and how did you find it?
What's the worst that could happen? After all, it's not like you're using this machine for important work.
Reply 3 of 8, by Cloudschatze
I imagine hardware differences probably need to be taken into account as well. In any event, here is at least one anecdotal account of the same "problem" (albeit, of a longer duration):
https://groups.google.com/forum/#!original/mi … M4/mby9pQIIbXcJ
I have those other, purportedly "essential," startup items disabled as well, including ScanReg. Some tweaking was necessary though - Because TaskMonitor has been disabled, "defrag" has been configured to not use the TaskMon-generated application profile, via registry-edit.
No, it doesn't seem to be disk related. This is a pretty bare-bones installation right now, consuming a little over a gigabyte of data, but yes, I did check to see if fragmentation might be involved.
This is the relevant key:
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Applets\SysTray\Services
There is some available information concerning changing the key value to achieve specific results (system-hang resolution, disabling the volume control, etc.), but nothing describing the correlation of the actual values to specific services. As such, I haven't modified the existing value at all.
Now, admittedly, this is a non-issue. Rather than disable SysTask, another solution would have been to simply make the "working-in-background" mouse pointer the same as the "normal" pointer, thereby disguising the goings-on. 😀 The real problem is that I now really want to know what SysTask is doing, and even the Windows 98 Resource Kit is coming up short of answers.
Reply 4 of 8, by Jorpho
Filemon and Regmon would be the way to go, though you might have to do some digging to find versions that will work with Windows 98, and persuading them to run before startup might take some doing. (Maybe you can use the old trick of renaming them as screensavers, and then wait for the screensaver to activate at the login prompt?) I think there should be a version of Autoruns for Win9x that also ought to be helpful.
Reply 5 of 8, by Cloudschatze
Opened-up Systray.exe in a hex editor last night, and basically confirmed that it's completely unnecessary in my configuration.
The Windows 98SE version (4.10.2222) enables the following system tray services:
- Power Status/Notification
- PC Card Status/Notification
- Volume Control
- USB Error Notification
The Windows 95 OSR2 version of Systray.exe (4.00.1111) lacks the USB notification features, and by substituting it into the Windows 98SE build, also resolves the "working-in-background" startup issue. Presumably, use of an earlier Windows 98 version might also provide the same result, and while I could do some additional testing to definitively find out, I continue to simply favor its exclusion.
Reply 6 of 8, by tincup
Wow, that delay always bugged me too. I have had Systray.exe as the only startup service enabled in msconfig for a long time now. I can't wait to try implanting the 95 version into 98 to see what happens. This is big news on the w98se front 🤣...
Reply 8 of 8, by Cloudschatze
No, I already had all power-management features disabled. It very much seems to be the USB notification funcationality in the 4.10.2222 version of SysTray that is to blame. I did take a look at the Windows 98 SysTray version (4.10.1998), and while it, like the Windows 95 version, also lacks the USB features, it requires a different version of BATMETER.DLL than the one included in 98SE. Not wanting to replace and re-register a DLL that I don't care about, I didn't test any further.
SNDVOL32.EXE is much more flexible when run separately, given the command-line switches, so unless you care about the PCMCIA and power-notification features, I highly recommend disabling Systray.exe altogether, rather than even bothering with the Windows 95 version substitution.
I vacillated about the use of Windows' volume control, but finally decided to just use Creative's mixer applications for the installed AWE64 Gold and SB Live!, and include shortcuts for them in the Quick Launch Bar area. The Windows option would have been to create two shortcuts to the SNDVOL32.EXE mixer instead (specifying the -d0 or -d1 switch for the respective soundcard).
