First post, by tgomola
I've got a problem with World Racing 2 on Windows 8.1. I've installed the game, patched it to 1.4.3 and run WR2_setup.exe to setup graphic settings (I set the resolution to 1366x768). However, when I start the game, the game seems to ignore the settings and runs at 1024x768. I didn't have this problem on Windows 7.
Any ideas?
My laptop spec: i7, GT755M + Intel HD 4600, 8 GB RAM.
EDIT: Nevermind, I've got it to work 😀 If any of you encounters such problem, here's the solution.
I've opened config.ini and changed the DeviceID setting. The default one was referring to my Intel GPU. After changed it to DeviceID=0x10DE0FCD (my GT755M ID), the game finally started to work properly.
