First post, by Great Hierophant
When playing Tex Murphy DVD, I have always had a slight problem. The original game shipped with support for only a few hardware MPEG2 decoders, but the last patch (1.04) allows for certain software MPEG2 decoder support. The recommended software decoder is Mediamatics' DVD Express. This will work, but has an annoying issue. When you have to respond to one of the characters, their image should freeze. However, with the Mediamatics' software, I have always seen a blank purple screen instead. Is this a common problem? Is there a software fix?
Reply 2 of 7, by Great Hierophant
Do you have any suggestions for a player that will run on Windows 98SE and work with this game? Which version of PowerDVD did you use?
Reply 3 of 7, by ElectricMonk
For what it's worth, I had similar issues using the GOG versions of Under a Killing Moon, Pandora Directive, and Overseer. Hope you get it to work!
Reply 4 of 7, by F2bnp
It's been a few years, but I think I just grabbed one of the many software CDs that came with DVD players in the early 00s!
Reply 5 of 7, by Totempole
Is the DVD version significantly better than the CD version?
My Retro Gaming PC:
Pentium III 450MHz Katmai Slot 1
Transcend 256MB PC133
Gigabyte GA-6BXC
MSI Geforce 2 MX400 AGP
Ensoniq ES1371 PCI
Sound Blaster AWE64 ISA
Reply 7 of 7, by Great Hierophant
Under a Killing Moon and The Pandora Directive were DOS games and do not support MPEG-2 DVD quality video. Any issues with those two games must have a different cause than the Windows-only Overseer.
