Far Cry
Getting old Windows games working.
Re: Far Cry
Postby lowenz » 2016-10-23 @ 20:50
FPS comparison (pure d3d9 vs wined3d)
Look at the MISSING water transparency with WineD3D 1.9.21.....
lowenz
Re: Far Cry
Postby lowenz » 2016-10-23 @ 21:01
Transparency back in proximity of the water:
lowenz
Re: Far Cry
Postby lowenz » 2016-10-23 @ 21:08
lowenz
Re: Far Cry
Postby Oubadah » 2017-2-22 @ 19:41
lowenz wrote:Look at the MISSING water transparency with WineD3D 1.9.21.....
I wasn't missing anything with 1.9.21:
Oubadah
Re: Far Cry
Postby lowenz » 2017-2-22 @ 22:28
The *water* transparency.
Time to test with 2.2 staging.
lowenz
Re: Far Cry
Postby Oubadah » 2017-2-22 @ 22:31
lowenz wrote:The *water* transparency.
My screenshot shows the same area of water that yours does. If you can't see the whole image, right click and open in new tab/window. This site can't properly reformat big images evidently.
Oubadah
Re: Far Cry
Postby lowenz » 2017-2-22 @ 23:17
Well, now the problem is gone with 2.2
http://fdossena.com/index.php?p=wined3d/index.frag
lowenz
Re: Far Cry
Postby Oubadah » 2017-2-22 @ 23:22
There was something weird going on it those screenshots of yours anyway. Where were the tree and rock reflections?
Oubadah
Re: Far Cry
Postby teleguy » 2017-2-23 @ 10:36
Oubadah wrote:There was something weird going on it those screenshots of yours anyway. Where were the tree and rock reflections?
He probably has r_Quality_Reflection set to 0.
teleguy
Re: Far Cry
Postby Res1s7 » 2017-12-26 @ 16:03
Hi. Has there been any update to this ? Is it a frame rate killer ? Or maybe I just had it setup badly last time. GOG: Should Far Cry bought from GOG have this problem fixed ? Is it responsibility of GOG ? I know it can't always be done. Original IP owner has to want to fix it. Availability of original source code, etc, etc.
Res1s7
Re: Far Cry
Postby lowenz » 2017-12-26 @ 17:25
First Binocular Point save: 290 FPS vs 120 FPS (i3 6300 + GeForce 1050 Ti) using Wine 3.0 RC1
Wine always necessary to fix the landmass reflections with the Steam version.
lowenz
Re: Far Cry
Postby CookiePLMonster » 2018-4-01 @ 19:04
Hey there,
Looks like WineD3D is still the only solution to fix water reflections and I never really was satisfied with this solution, so decided to give it a try and... there it is!
Water reflections rely heavily on user clip planes (so bottom surfaces of water pools don't get reflected), and for reasons unknown behaviour of IDirect3DDevice9::SetClipPlane has changed between XP and Vista/7/8.1/10. Even though D3D9 is supposed to work like a finite state machine, state of clip planes did not persist properly between draw calls (either that or maybe there is some precomputation applied to it) - so my fix is to re-apply clip planes before every draw call.
Works flawlessly, native D3D9, no performance hit!
For reference that it's legit (though I admit the timing is sub-par), I'm an author of several unofficlal patches for other games.
Cheers!
User avatar
CookiePLMonster
Re: Far Cry
Postby lowenz » 2018-4-01 @ 20:15
Thanks man!
lowenz
Re: Far Cry
Postby Johnylyr » 2018-4-01 @ 20:42
CookiePLMonster wrote:Hey there,
Cheers!
So where is the patch? And what about d3d10;
User avatar
Johnylyr
Re: Far Cry
Postby CookiePLMonster » 2018-4-01 @ 21:21
Johnylyr wrote:So where is the patch? And what about d3d10;
Soon! And not sure what you mean by D3D10, as far as I'm aware FC1 doesn't have a D3D10 renderer.
Actually, is there anyone with AMD (or Intel) GPUs here who could volunteer as a tester for this? So far I could only confirm it working on NVidia GPUs.
User avatar
CookiePLMonster
Re: Far Cry
Postby Srandista » 2018-4-02 @ 00:11
CookiePLMonster wrote:Actually, is there anyone with AMD (or Intel) GPUs here who could volunteer as a tester for this?
I have both of them, if you want to test it on Win 10.
My overkill "retro" PC - Pentium E6500K, 512MB/2GB RAM, Radeon 9500@9700 (Softmod), 80GB HDD, Win 98/XP
User avatar
Srandista
Re: Far Cry
Postby lowenz » 2018-4-02 @ 00:34
The patch will be a modified D3D9.dll? I ask 'cause of reshade......
lowenz
Re: Far Cry
Postby CookiePLMonster » 2018-4-02 @ 09:25
Cool! I'll post when I have something which can be tested.
lowenz wrote:The patch will be a modified D3D9.dll? I ask 'cause of reshade......
That's what I was worried about... I did want it to be d3d9.dll (because the game breaks Ultimate ASI Loader badly at the moment), but you have a good point... I'll see if I can make it into an ASI plugin. Will most likely need to ship ASI Loader as gdi32.dll then, as pretty much no other DLL works well (dinput8 loads too late and dsound is unreliable).
However, I may also publish this as d3d9.dll and issue a pull request to ReShade with the same changes.
EDIT:
Interesting - looks like the game supports a D3D8 renderer! Did any version of the game come with XRenderD3D8.dll?
User avatar
CookiePLMonster
Re: Far Cry
Postby lowenz » 2018-4-02 @ 09:41
The "pure" D3D8 renderer isn't removed in the 1.4 update?
lowenz
Re: Far Cry
Postby lowenz » 2018-4-02 @ 09:48
CookiePLMonster wrote:dsound is unreliable
And taken for Indirect Sound :D -> http://www.indirectsound.com/
Good idea!
lowenz
PreviousNext
Return to Windows
Who is online
Users browsing this forum: No registered users and 2 guests
