First post, by VirtuaIceMan
Also asked this on AssemberGames, but will ask here too:
I'm trying to get the UK (if that matters) version of South Park Rally (by Tantalus/Acclaim) to work on my Win8.1 64bit PC. I've seen people say it works on Windows Vista and even Win7 64bit, so I was hoping I might get somewhere.
It installs fine, and patches fine (the 1.01 patch), but running the config or game throws this into the games own debug.log file... I've tried compatibility modes in Win8.1 but nothing helps much. I also tried a no-CD crack, and copying part of the game files from my old XP machine, so far nothing works.
Here's the log file (no compatibility modes):
+ (INFO) startup: Project - South Park Rally+ (INFO) startup: Date - May 3 2000 12:34:16 + (INFO) startup: Version - WXPRE065 + […]
+ (INFO) dinput: found device - [DIDEVTYPEMOUSE_UNKNOWN , Mouse]
+ (INFO) dinput: found device - [DIDEVTYPEKEYBOARD_PCENH , Keyboard]
+ (ERROR) SearchPath = 'D:\Games\sparkral;C:\Windows\system32'
+ (ERROR) INFO: handle: 2a4 procid: 14fc thread: fffffffe
searchpath: D:\Games\sparkral;C:\Windows\system32
+ (ERROR) **************************************************************************
+ (ERROR) (EXCEPTION) : EXCEPTION_ACCESS_VIOLATION
+ (ERROR)
+ (ERROR) Registers:
+ (ERROR) EAX=0078e410 CS=0023 EIP=6a591211 EFLGS=00010246
+ (ERROR) EBX=04000a00 SS=002b ESP=0018f624 EBP=0018f660
+ (ERROR) ECX=0078f004 DS=002b ESI=0078ea1c FS=0053
+ (ERROR) EDX=0077d420 ES=002b EDI=00000078 GS=002b
+ (ERROR)
+ (ERROR) CallStack:
+ (ERROR) dinput!DirectInputCreateEx+5f37h
+ (ERROR) dinput!DirectInputCreateEx+70a8h
+ (ERROR) dinput!DirectInputCreateEx+77bfh
+ (ERROR) dinput!DirectInputCreateEx+51b1h
+ (ERROR) dinput!<nosymbol>+0h
+ (ERROR) dinput!DirectInputCreateEx+248h
+ (ERROR) dinput!DirectInputCreateEx+291h
+ (ERROR) dinput!DirectInputCreateEx+209dh
+ (ERROR) dinput!DirectInputCreateEx+48ah
+ (ERROR) dinput!DirectInputCreateEx+565h
+ (ERROR) mercury2!mlINPUT_ResetDevice+1b1h
+ (ERROR) sprally2!mlCOLLISION_IsPointInConvexPolygon2+7d970h
+ (ERROR) KERNEL32!BaseThreadInitThunk+eh
+ (ERROR) ntdll!RtlInitializeExceptionChain+84h
+ (ERROR) ntdll!RtlInitializeExceptionChain+5ah
+ (ERROR) Failed to StackWalk
ERROR CODE: 0
With compatibility mode set to XP (SP2), the log file looks like this:
+ (INFO) dinput: found device - [DIDEVTYPE_UNKNOWN , HID-compliant vendor-defined device]
Also, Windows Event Viewer logs this:
Faulting application name: sprally2.exe, version: 1.0.0.0, time stamp: 0x390f906c Faulting module name: sprally2.exe, version: 1 […]
Faulting module name: sprally2.exe, version: 1.0.0.0, time stamp: 0x390f906c
Exception code: 0xc0000005
Fault offset: 0x00087367
Faulting process ID: 0x1194
Faulting application start time: 0x01d00909bbe98c64
Faulting application path: D:\Games\sparkral\sprally2.exe
Faulting module path: D:\Games\sparkral\sprally2.exe
Report ID: f9aead0e-74fc-11e4-828e-7824af8a9e0a
Faulting package full name:
Faulting package-relative application ID:
Anyone got any ideas? I tried in ACT the profile for South Park Rally, but that doesn't work either, throwing a Windows Event Viewer log of:
Faulting application name: sprally2.exe, version: 1.0.0.0, time stamp: 0x390f906c Faulting module name: ntdll.dll, version: 6.3. […]
Faulting module name: ntdll.dll, version: 6.3.9600.17278, time stamp: 0x53eeb4a3
Exception code: 0xc0000409
Fault offset: 0x0007660a
Faulting process ID: 0x122c
Faulting application start time: 0x01d0090a33eddf4d
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report ID: 71ad26ef-74fd-11e4-828e-7824af8a9e0a
p.s. I realise the game's a bit rubbish, and there's an N64/Dreamcast version that can be emulated, but that's not the point 😁
Reply 2 of 5, by VirtuaIceMan
What spec is your 8.1 machine?
Reply 4 of 5, by VirtuaIceMan
Ah, I'm on i7-4790K, 16GB RAM, GTX 980. Maybe it's a graphics driver issue (often is with Nvidia, though to be honest I've been dead impressed with how many games I can get working fine, or better than XP, on Win8.1 with the latest graphics drivers!)
Reply 5 of 5, by VirtuaIceMan
Confirmed FIXED! By removing the USB link cable from my H100i water cooling system, see here: FIXED see pg 5: Why does my new PC crash games that work for other people? Lengthy testing results within, please help!
