obobskivich wrote:What exactly are you doing with a GFWL "emulator" here? Have you tried re-installing the game properly and not touching GFWL (from what I remember it does not require it anymore than Fallout 3 does, you just leave it alone and it leaves you alone, but unlike Fallout 3 I'm not aware of a mod that will remove it from the menus (which in the case of Fallout 3 is just useful because it helps it start-up faster)).
Well, it had crashed on me when I tried it without the emulator, and with GFWL installed, and it kept crashing, it was only when I installed the emulator that it started up.
obobskivich wrote:What about your soundcard?
I don't have a soundcard...
obobskivich wrote:FWIR these games aren't models of stability, and IME it's usually the audiocard/settings that bring them down - just like the Hitman games that share the same engine. However I don't ever remember having to do anything beyond installing it and running it on a relatively similar machine (Win7x64, Radeon graphics, etc) - it'd crash from time to time, but that's about it. Any reason you're averse to just logging into GFWL and letting it download the patch? (I know, I know, GFWL isn't great, but for the few games that use it exclusively (like this, and Fallout 3), it isn't bad either - it's usually only a problem when it tries to "stack" with other digital download services like Steam and Origin (e.g. BioShock 2)).
I have no issue with GFWL, in fact I can bare it more than Steam, Origin and Uplay combined, but like I said before, I never got it running with the real client.
obobskivich wrote:If you're avoiding GFWL because you've pirated the game, you should go buy a legal copy. It's not an expensive game. It's $1.74 from Amazon:
http://www.amazon.com/Kane-Lynch-Dead-Men-Dow … /dp/B009IXNPDE/
Don't worry, I have the genuine copy, I have 2, actually, the first one wouldn't install because the disc was too damaged, but the second copy installed just fine.
I can prove I own the actual game if you need me to.
mirh wrote:I'm indeed not sure of what you mean with GFWL emulator...
Though I'll try to assume you have a legal copy....
I didn't want to link to the emulator, because it's from a forum that commonly posts pirate downloads for PC games, but a lot of people, like myself, just go to it for getting tools to work around DRM for legal games.
It's a simple dll (xlive.dll) that you just stick into the game's directory and run the original exe.
mirh wrote:And the solution to any GFWL problem is... just to update the client.
http://www.xbox.com/LIVE/PC/DownloadClient
Regards
I just tried that, and I registered my game, and it worked! The game finally went beyond the first cutscene, and there was no patch as far as I was aware. The problem must've been the fact I got an achievement after the first level, xLive (the emulator) doesn't support those yet, so that might've caused the crash...
Thanks for all of your help anyway!
