First post, by Gamecollector
- Oldbie
Have tested Tiger Woods PGA Tour 2003 with my WinXp PC.
There is 1 trouble - the installer freezes if yo finish/cancel the setup trosess. As the result - setup.ilg isn't created and I can't uninstall the game properly...
Tested with 1 PC and 2 notebooks, the result is same.
TW2k3 uses InstallShield6 (6.31.100.1019) and installs it to Program Files\Common Files\Installshield\Engine\6\Intel32\
Strangely enough TW2k3 installer works correctly with Vista. And other games/programs with the same InstallShield version works ok (3dmark 2001, Tiger Woods PGA Tour 2002 etc).
I have attached needed files to test this.
1) Can someone with a WinXp PC test this pack? Maybe all my PCs are affected by my admin skills and the reason is't IS6.
2) Can someone with enough skills find the reason for this freeze and the fix?
Tnx.
