First post, by noshutdown
os is windows98 only, with the built-in bootmenu enabled.
i want to load emm386 when i choose "5.command prompt only" as some old games requires ems to run, but not when i choose "1.normal", is there anyway to do that in config.sys?
Reply 1 of 3, by collector
This is the Windows games forum. If you are having to mess with the config.sys then you must be talking about DOS games, not Windows games.
Reply 2 of 3, by Jorpho
There shouldn't be anything wrong with loading EMM386 when Windows is running normally; it is specifically designed not to affect Windows. Do you have some reason to suspect that EMM386 is causing a problem?
