International Rally Championship (Magnetic Fields/Europress) - how to install if setup.exe won't work
First post, by VirtuaIceMan
The setup.exe file will probably crash with a "Guru Meditation" error, so perform a manual install as follows:
1. Create a folder to install the game into, e.g. c:\games\irc
2. Go into the new folder
3. Copy from the CD-ROM the following files into these locations:
- the whole "files" folder into the game folder, i.e. so you have c:\games\irc\files
- ral.exe into the game folder, i.e. so you have c:\games\irc\ral.exe
4. Create 2 more sub-folders in the game folder, called "savedata" and "var"
5. Go into the "var" folder and create a new text document, in it put the following - and change the CD-ROM for the correct drive letter that you have the game in:
; International Rally Championship
; INSTALLATION CONFIGURATION
cdrom=d:\
installation=3
6. Rename this text document (you'll need to be able to see extensions in Windows to do this) to ral.zog
7. Go up one level to the main folder again. Now you need to create a sub-folder called "savedata", so you have c:\games\irc\savedata
8. Go into the new savedata folder and create the following folders:
c:\games\irc\savedata\carsetup
c:\games\irc\savedata\ghosts
c:\games\irc\savedata\hst
c:\games\irc\savedata\levels
c:\games\irc\savedata\replay
c:\games\irc\savedata\savegame
8. Download the 4.80 patch from Patches Scrolls http://www.patches-scrolls.de/patch/2217
9. Copy the ral.exe file from the zip 4.80 patch into the game folder and overwrite the existing ral.exe
10. Right-click on ral.exe in the game folder and choose Win95 or Win98 compatibility mode
11. In order to get the full framerate, follow the guide on this site (either download their DDRAW.dll or use ACT): http://www.blitzbasic.com/Community/post.php? … 77&post=1202630
12. Run ral.exe and hopefully the game will load!
13. The game may crash if you use the non-Direct3D 8bit graphics version, so go into the Options > Settings > Visual Display and ensure 16bit accelerated is chosen
14. Set everything else up as you wish and play away!
15. You can set up a shortcut to ral.exe if you wish.
NOTE: there is one issue: when you press Escape in-game, the menu will be invisible. So if you want to exit the current race, press up once, then press return, then up once again and return again!
NOTE 2: the original game did install some Registry strings, but the game seems to run fine without them
Reply 2 of 3, by tgomola
When I try using ACT / modified ddraw.dll, the menus and HUD flicker like crazy, making the game unplayable (although the framerate does improve). On the other hand, using dgVoodoo's ddraw.dll fixes the flickering as well as framerate, but some objects are not rendered correctly - mainly the bushes on both sides of the road (only those closest to the car, the farther ones are OK).
I play the game on Win8.1 x64, i7 and GT755M.
Reply 3 of 3, by Procyon
Thanks!
I have the game working on Windows 10 with dgVoodoo 2.
The game does have sound issues though and I tried making single core affinity script but it doesn't remedy it.
Maybe you should put this on PC Gaming Wiki?
https://pcgamingwiki.com/wiki/International_R … ly_Championship
