First post, by VirtuaIceMan
1. Install the game from CD-ROM.
2. Install the 1.09 patch from here: http://www.patches-scrolls.de/patch/919
3. Set compatibility mode on the Colin McRae Rally 2 shortcut to WindowsXP (doesn't matter which). If you don't, the game won't start at all.
4. Test if it works. You'll notice a window border around the game and a less-than-smooth framerate. Note: on my monitor for in-game resolution I can't use the maximum (stretched anyway) 2560x1440 resolution (as the game crashes setting it), so I go for 1920x1080 instead.
5. To remove the border and get full framerate (lovely and smooth), either drop a modified DDRAW.dll file into the game folder, or use ACT on both game.exe and rally.exe with the fixes listed here (I prefer ACT as it's not using a potentially one day out-of-date DDRAW.dll): http://www.blitzbasic.com/Community/post.php? … 77&post=1202630
Issue: the opening videos (if they even displayed for you before, with a border) now will show black, just press Return twice to skip them.
Enjoy!
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
Reply 1 of 1, by VirtuaIceMan
UPDATE: changes for ACT as follows:
1. Remove the DXPrimaryEmulation tick and replace it with NoGDIHWAcceleration (you'll now see intro videos)
2. Tick fix ForceSimpleWindow (to remove borders)
