First post, by VirtuaIceMan
FIXED; it was Bink version included with the game, thanks to ZellSF, scroll down this thread for more.
Running F1RC, you see the opening videos, then crash to desktop.
Event Viewer reports this:
Faulting application name: F1RC.exe, version: 1.0.0.1, time stamp: 0x31313931
Faulting module name: F1RC.exe, version: 1.0.0.1, time stamp: 0x31313931
Exception code: 0xc0000005
Fault offset: 0x0014626b
Faulting process ID: 0x1474
Faulting application start time: 0x01d04fbea1a71497
Faulting application path: D:\Games\f1rc\F1RC.exe
Faulting module path: D:\Games\f1rc\F1RC.exe
Report ID: e20e69e8-bbb1-11e4-8309-7824af8a9e0a
Faulting package full name:
Faulting package-relative application ID:
The game itself saves a crash.log file, which contains this:
CrashLogVersion 2
Date 15/02/23 23:15:41
Module: F1RC.exe
Version: R.1.00.004
Infos: -
Exception "Acces Violation" (address 0000000C is unreadable) at :
0054626B
EAX 000EA600
EBX 000EA600
ECX 00000000
EDX 000EA600
ESI 00000000
EDI 000EA600
EIP 0054626B
FLG 00210202
EBP 00000001
ESP 000CF9A0
Code from 0054626B to 0054628B :
8A 46 0C 84 C0 75 0A 5F 5E 5D 33 C0 5B 83 C4 0C
C3 8B CE E8 5D 04 00 00 84 C0 75 0A 5F 5E 5D 33
Stack from 000CF9A0 to 000CFDA0 :
00000001 020F6968 00000001 000EA600
00000004 01010004 00010000 004BE8BF
00000001 01D41558 00000007 00257E38
40000F40 000C0000 00000000 00000000
0B3C0000 00000270 00000000 00000000
00000000 001E7600 00000000 00000000
00000000 00000000 00000000 00000000
00000001 00000000 40000F40 000C0000
00000000 00000000 00000000 00000270
00285000 000CFAC0 6175E460 00000000
000CFAE4 00000000 00257E38 000CFAE4
05084DF0 003D0000 00000000 00000000
I tried compatibility modes and fiddling the the MapMemoryB0000 ACT fix, no luck yet.
In the semi-sequel, Racing Simulation 3, Event Viewer:
Faulting application name: RS3.exe, version: 2.0.0.16, time stamp: 0x3dbfb216
Faulting module name: RS3.exe, version: 2.0.0.16, time stamp: 0x3dbfb216
Fault offset: 0x0015a1fb
Faulting process ID: 0x1278
Faulting application start time: 0x01d04fcffe0c7301
Faulting application path: D:\Games\rs3\RS3.exe
Faulting module path: D:\Games\rs3\RS3.exe
Report ID: 4750335b-bbc3-11e4-8309-7824af8a9e0a
And crash.log:
CrashLogVersion 2
Date 15/02/24 01:20:12
Module: RS3.exe
Version: R.2.00.016
Infos: -
0055A1FB
EAX 000EA600
EBX 000EA600
ECX 00000000
EDX 000EA600
ESI 00000000
EDI 000EA600
EIP 0055A1FB
FLG 00010202
EBP 00000001
ESP 000CF9A0
Code from 0055A1FB to 0055A21B :
00000001 02B86968 00000001 000EA600
00000004 01010004 00010000 005197BF
00000001 02AF5174 00000007 0017D0D8
0BF70000 00000270 00000000 00000000
00000000 00317600 00000000 00000000
001AB000 000CFAC0 6025E460 00000000
000CFAE4 00000000 0017D0D8 000CFAE4
05A079D0 125AD5B1 000000FE 00000000
Reply 1 of 12, by VirtuaIceMan
These aren't fixed yet, i.e. not caused by my water cooler USB cable(!). I just Googled about and found this: http://www.theisonews.com/forums/index.php?topic=52191.0 where someone has had the crashes on Win2000 and Win98, so it's NOT a Win8.1 thing.
I believe I had the demo for F1RC working though, either on my work Win7 64bit machine, OR on my home machine running Win7 64bit, I'm going to investigate further on this one...
Reply 2 of 12, by VirtuaIceMan
Please can everyone(!) try this demo and let me know if it works? The installer just unzips the game to a folder, you don't even need to install anything into Windows! http://www.fileplanet.com/55761/50000/fileinf … ampionship-Demo
My results:
Fails:
- Home PC (spec in my signature) = crashes with errors above (NOTE: will double-check later, as the errors relate to the full games)
Works:
- Work PC (Win7 64bit, i7 870 3GHz, ATI Radeon HD 4600, AMD/onboard sound, 8GB RAM)
- Old home PC (WinXP 32bit, Pentium4 3.2GHz EE, Gainward GeForce 7800GS+, Creative Soundblaster Audigy ZS2, 3GB RAM
Reply 3 of 12, by Stiletto
crashed for me, basically identical to what you said.
Specs: HP Envy dv6-7246us running Windows 8.1 64-bit
do the Fandango!" - Queen
Stiletto
Reply 4 of 12, by ZellSF
I got the same crash on the demo.
Then I replaced binkw32.dll version 1.9.99.0 (1.99a) of that file and it worked (and did not break video playback).
Bink's pretty known for compatibility issues.
Reply 5 of 12, by ZellSF
Same thing with full version, except: intro video doesn't play. Track flybys still play though.
if you want intro videos might want to look for other bink versions, or other games with similar bink problems and see what solutions they come up with. I don't care, but now you know where to look 😀
Reply 6 of 12, by VirtuaIceMan
Yeah you're right, it must be the version of Bink included, when it unloads after the intro video, crashes the game!
I'm researching now which of the multitude of Bink's I have with other games works better (if any). More news soon...
Reply 7 of 12, by VirtuaIceMan
Okay solved it. Any 1.99 version of Bink will make the game work, but without video. However if you use version 1.8 (the newer version from 2007-2008 era) then the video will be visible! I have that dll with Juiced2 and Lost Via Domus.
Quick tip: if you run the game with CD protection (i.e. not a crack) then click on the CD check pop-up when it appears, otherwise the game may not boot fullscreen properly after the check pop-up disappears (not without using WinXP compatibility or something).
Second tip: apply Application Compatibility Toolkit option NoGDIHWAcceleration if on Win8 or 8.1 to get >30fps in-game.
p.s. the intro video may be a bit flickery, but at least it's there!
Reply 8 of 12, by Agathosdaimon
Sorry raise this one again, but just further on my crusade to get old F1 games working.
I basically bought a bunch off ebay and now today this one has arrived and i have it working using the advice above and it looks great - except for one thing, the in game pause menu is missing. - i kan use the arrow keys to select options (a bit of trial and error) but the graphic of the ingame pause menu is missing (it should appear when one presses escape) - is there a way i can fix this?
I am running the game on Windows 10 64bit.
also i noticed in the original FAQ it mentioned the game was tested on voodoo cards and with 3dfx drivers - is there any way to have the game work and recognise NGLIDE? this might fix the missing menu perhaps
cheers
Mitchell
Reply 9 of 12, by mrpenguinb
Agathosdaimon wrote:
Sorry raise this one again, but just further on my crusade to get old F1 games working. […]
cheers
Mitchell
Have you tried to use dgVoodoo? Or else you could use NGlide, I have had success with it in other games before.
Reply 12 of 12, by VirtuaIceMan
Menus go missing if you run with fancy anti-aliasing on. If you use FXAA (I think) it works.
