First post, by VirtuaIceMan
- Oldbie
Seems I'm falling into a pit of failing F1 titles... F1 2000 doesn't do anything for me, even in software mode, just crashes with Event Viewer:
Faulting application name: F1_2000.ICD, version: 1.0.9.0, time stamp: 0x3937d63a
Faulting module name: F1_2000.ICD, version: 1.0.9.0, time stamp: 0x3937d63a
Exception code: 0xc0000005
Fault offset: 0x000e7389
Faulting process ID: 0xbbc
Faulting application start time: 0x01d04fc393c8606b
Faulting application path: D:\Games\f12000\F1_2000.ICD
Faulting module path: D:\Games\f12000\F1_2000.ICD
Report ID: d6408777-bbb6-11e4-8309-7824af8a9e0a
Faulting package full name:
Faulting package-relative application ID:
It's crashing the .ICD due to the SafeDisc DRM on the disc, however if I swap to a no-CD it just crashes f1_2000.exe instead. Any ideas? This is using the 1.09 patch with or without ALchemy.
Moving on to the "sequel", F1 Championship Season 2000, I get the same sort of thing:
Faulting application name: F1CS2000.ICD, version: 0.5.8.0, time stamp: 0x3a0720f1
Faulting module name: F1CS2000.ICD, version: 0.5.8.0, time stamp: 0x3a0720f1
Fault offset: 0x0011b4a9
Faulting process ID: 0x1750
Faulting application start time: 0x01d04fc641d9824e
Faulting application path: D:\Games\f1cs2000\F1CS2000.ICD
Faulting module path: D:\Games\f1cs2000\F1CS2000.ICD
Report ID: 83994706-bbb9-11e4-8309-7824af8a9e0a
I'm wondering if it could be related to graphics possibly, as the VIDEO.CFG for F1CS2000 has this. I'll compare it against my old XP machine at some point...
[Direct3D Primary]
DeviceName="NVIDIA GeForce GTX 980"
AllowWindowed=1
WinOverride=0
TotalMem=-1009
AvailMem=0
Mode_320x240=0
Mode_400x300=0
Mode_512x384=0
Mode_640x400=0
Mode_640x480=0
Mode_800x600=0
Mode_1024x768=0
[Direct3D Secondary]
AllowWindowed=0
WinOverride=0
TotalMem=-1024
AvailMem=0
Mode_320x240=0
Mode_400x300=0
Mode_512x384=0
Mode_640x400=0
Mode_640x480=0
Mode_800x600=0
Mode_1024x768=0
[Software]
DeviceName="CUBE Render Technology"
AllowWindowed=1
WinOverride=0
TotalMem=-1009
AvailMem=0
Mode_320x240=0
Mode_400x300=0
Mode_512x384=0
Mode_640x400=0
Mode_640x480=0
Mode_800x600=0
Mode_1024x768=0
Strangely the older, similar engined game by ISI, Sports Car GT, works fine (though that uses Glide to run optimally)...
My PC spec: Win10 64bit, i7-4970K (not overclocked), KFA2 GeForce RTX 2070 SUPER, Creative Soundblaster ZXr, 16GB RAM, Asus Z97-A motherboard, NZXT 410 case, ROG Swift GSYNC monitor
