First post, by stuntpup
I bought this when it first came out and it installed fine back then on a win98 direct x 6 pc. It refuses to install if the directx version is higher, and this is noted on the awesome dev website. In fact they say to install it you have to reboot the pc mid-install !! .. they also mention to return the cd for a newer version but thats prolly old news now.
Is there a way to trick the install that direct x 6 is installed ? .. or has anyone found another way to get this working ??
