Hello all,
Thanks a bunch to poster Gerwin's tip above, I have got the MIDI music WORKING for Jane's Fighter's Anthology (FA) AND USNF '97! 😀
This was tested in XP 32-bit on two computers. I have included all my background info below, but in a nut shell it is this:
- Install either game (MIDI version in FA's case of course)
- BEFORE running them, set the shortcut to 95/98 compatibility mode.
- That's it!
It is IMPORTANT to do this BEFORE running the games. The reason is, that if you run them without 95/98 compatibility mode on, not only does the music not work, but the EA.CFG file seems to get permanently messed up. The music won't play even if you turn compatibility mode on later. Wierd. You'll have to either delete EA.CFG or restore it from a backup (like Gerwin's "Janes-FA-config-midi.zip" above, or my attached file below, see details below).
The one drawback of my discovery is that in 95/98 compatibility mode, the mouse cursor gets very jerky in the interface. I don't know why. It is less jerky on my Toshiba A200 laptop than my AMD dual-core GTX480 desktop - go figure. If you can click the "Single Mission" button, you can press Enter multiple times to get into the cockpit and you'll hear the music. Any input on this quirk would be more than welcome.
Finally, if you want to run FA and switch between MIDI and WAVE music, or are just curious, see all the details below:
Fighter Anthology with WAVE/Digital music:
- Install with Wave install
- Run - Wave music in menu and flight
- Done
Fighter Anthology AND/OR USNF 97 with MIDI music:
- Install (MIDI install in FA's case)
- Set shortcut to 95/98 compatibility mode
- Run - Wave music in menu (FA only), MIDI in flight
- Note: Mouse cursor very jerky
- Done
- Recommend backing up EA.CFG in case game is run without 95/98 compatibility mode, can then restore EA.CFG
- Setup all prefs graphics joystick etc before backing up EA.CFG, won't have to do it all over again
Fighter Anthology switchable WAVE or MIDI music:
- Install FA Wave install
- Run FA - setup prefs graphics joystick etc etc as desired
- Backup EA.CFG somewhere as EAWave.CFG
- Backup FA_4B.LIB (wave music library)
- Uninstall
- Re-Install with MIDI install
- Backup EA.CFG as EAMidi.CFG
- Put FA_4B.LIB into install dir (wave music)
- Done - wave music in menu, MIDI in flight
- To switch to wave: copy in EAWave.CFG as EA.CFG
- Optional: Turn off 95/98 compatibility mode (smoother mouse cursor).
- To switch back to midi: copy in EAMidi.CFG as EA.CFG
- Turn on shortcut 95/98 compatibility mode
Notes:
If compatibility mode set to 2000 or XP def / off, music stops
Set back to 95/98, STILL no music.
Have to delete / copy EA.cfg again (gets 'messed'):
DELETE EA.cfg / or copy from Gerwin's "Janes-FA-config-midi.zip"
If adding Wave music to MIDI install, it needs FA_4B.LIB from a wave installation
If you want I can try uploading FA_4B.LIB (35MB) if you don't want to bother installing FA WAVE first.
I've attached Config files for FA Wave, FA Midi, and USNF '97. These work, AS LONG AS you set 95/98 compatibility mode for the MIDI versions BEFORE running them. Rename to EA.CFG of course. I've also set up some basic prefs, joystick, HUD, graphics, etc so you're not back to stock everytime.
- Filename
- EA (FA Wave).CFG
- File size
- 343 Bytes
- Downloads
- 110 downloads
- File comment
- FA Wave Music Config File (EA.CFG)
- File license
- Fair use/fair dealing exception
- Filename
- EA (FA MIDI).CFG
- File size
- 343 Bytes
- Downloads
- 136 downloads
- File comment
- FA MIDI Music Config File (EA.CFG)
- File license
- Filename
- EA (USNF97).CFG
- File size
- 340 Bytes
- Downloads
- 136 downloads
- File comment
- USNF 97 Config File (EA.CFG)
- File license
Finally, a small gameplay tip: When you're in the cockpit, press the - (minus) key until it zooms out -100%. Otherwise it's like looking through blinkers, and the ground speed looks a tad more realistic. I think the game looks MUCH better that way, especially landing.
Let me know if there's anything else - cheers! 😀
Bellarmine
When working on a job, you have 3 criteria: Fast, Good, and Cheap (i.e., Quick, High Quality, and Low Cost). Only 2 out of 3 are practical.
