Steam Killed My XP Install
First post, by boxpressed
Back in 2004 or 2005, I purchased the Half Life 2 Collector's Edition at retail. I didn't install it until 2011. I remember being surprised that I needed to set up a Steam account in order to play the game (I was behind the times with regard to DRM). Eventually, I got it up and running but never really played it. I then took a decade-long hiatus from computer games.
Yesterday, I tried to install HL2 again on my recently-acquired "late-XP" build, an AMD Phenom II X4 940 with a Geforce 9800GT. My install of XP Home SP2 was almost completely fresh: just mobo drivers, wireless keyboard/mouse drivers, Forceware 178.24, Wireless 802.11G driver, Doom 3, and Far Cry.
I was torn installing Steam because I wanted this build to not connect to the Internet at all (I only did once -- to activate XP). But I really wanted to play HL2, so I did the full install.
Well, Steam tried to update itself from its 2004 version. It seemed to stall and take a long time. Eventually, it did update because the splash screen changed. However, about ten seconds after XP loaded, the computer would spontaneously reboot. It cycled through this sequence a few times before I reimaged the drive.
Does anyone have experience with loading Steam on a XP SP2-era install? Would updating to SP3 make a difference? Or adding NET Framework 4? Maybe install Steam from the Steam website before trying to install HL2 from the DVD?
I do have a Steam account that recognizes my HL2 purchase. Appreciate any advice.
Reply 1 of 30, by ZellSF
Uh, Steam's just a piece of software, it does not install DRM drivers or anything like that. All you had to do was remove it from your startup folder, not re-image the entire computer.
That said, even that shouldn't happen: I suspect your XP setup dying is entirely unrelated to you installing Steam.
Reply 2 of 30, by boxpressed
I didn't realize it was in the startup folder, and I could have gone into Safe Mode to remove it.
However, I'm pretty sure it did something to my install. Everything else about it works as it should.
Reply 3 of 30, by Jorpho
Then yes, all you have to do is download Steam from the official site and install Half-Life 2 from there. Even if you try to install HL2 from the DVD, it will probably want to update itself anyway.
Reply 4 of 30, by teleguy
Why did you install the 2004 version first and not download the newest one?
Reply 5 of 30, by Lo Wang
If software pirates had the certainty that they would be immediately put to death upon arrest, legitimate users wouldn't be dealing with all this drm garbage today.
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved" - Romans 10:9
Reply 6 of 30, by boxpressed
I thought I had to install HL2 off the DVD first. The install loads HL2 (plus other games) and Steam all at the same time. Then Steam starts to update itself automatically.
I will go ahead and load the latest version of Steam off the website and see how that goes.
Reply 7 of 30, by PhilsComputerLab
I have installed Steam on XP sp2. I just put the latest installer on a USB and installed it that way.
YouTube, Facebook, Website
Reply 8 of 30, by boxpressed
I used the installer on the Steam website and loaded the latest version. It did the same thing! Steam would load, then the computer would reboot.
This time, I disabled the Steam startup in Safe Mode. Then, I went ahead and installed SP3 just for kicks. If there was no change, I'd reimage again.
This time it worked. So, for whatever reason, my system needs some fix from SP3 or Steam will begin a loop of reboots.
I went ahead and loaded HL2 and the other games from the DVD. However, when I tried to run them, Steam wanted me to download and install it rather than running the version off the DVD.
Obviously, I'm behind the curve with the state of DRM, but what I don't really understand is why even have a DVD-ROM at all? If Steam will only allow you to run the version on its servers, why even have retail packaging? Maybe I'm missing something here.
Reply 9 of 30, by DosFreak
Uncheck option in "Startup and Recovery" in sysdm.cpl to not automatically restart so you can at least see the BSOD.
As for the Steam requirement last time I converted my copy to load without Steam was with RevEmu back in 2011. Unknown if that method still works today.
The DVD was for when Steam was still in it's infancy and for those without the bandwidth to download the game. The retail ver still requires Steam and when you install it will want to download the difference. There have been alot of updates over the years.
Make your games work offline
Reply 10 of 30, by boxpressed
OK, so I guess that some Steam games are "modular," with a chunk on the DVD and a variable chunk to be downloaded. I did notice that there were two "Half Life 2" applications in my program listing in the control panel. One was about 3.5GB, and one was about 1.0GB.
Reply 12 of 30, by Jorpho
Even when the game was originally released there were lots of people who were absolutely furious that it insisted on doing a massive download as soon as it installed. Steam was mighty unpopular for a while.
Yes indeed, it is kind of silly.
Yarg, I forgot about that. That is a very good idea. (It should also turn up in Event Viewer in Administrative tools.)
Reply 13 of 30, by RacoonRider
I use Steam on my XP SP2 Athlon3200+/Radeon9800Pro machine. No problem so far. Autorun is disabled so that I don't have to listen to it whining about the absent internet connection.
I also use this machine for internet from time to time. It has no anti-virus software whatsoever and I don't care. If you don't go pirating from unreliable sources or watching porn, you're pretty much safe. Viruses do not appear without reason.
Reply 14 of 30, by PhilsComputerLab
Cool! I was wondering about Steam and the requirement for SSE2. Looks like it's working 😀
Can I ask you what driver you're using for your Radeon? Something period correct, or the latest?
Reply 15 of 30, by VirtuaIceMan
I think Steam updated Half Life 1 and possibly 2 a fair few times (as I've had numerous updates over the years). Hopefully none of them made it less compatible with XP?
Reply 17 of 30, by calvin
Valve is good with compatibility. I see in the beta channel they still support Athlon XP for Steam.
2xP2 450, 512 MB SDR, GeForce DDR, Asus P2B-D, Windows 2000
P3 866, 512 MB RDRAM, Radeon X1650, Dell Dimension XPS B866, Windows 7
M2 @ 250 MHz, 64 MB SDE, SiS5598, Compaq Presario 2286, Windows 98
Reply 18 of 30, by Firtasik
The latest version of Half-Life 2 can be launched without Steam.
Half-Life 2 - hl2.exe
Half-Life 2: Episode 1 - hl2.exe -game episodic
Half-Life 2: Episode 2 - hl2.exe -game ep2
Half-Life 2: Lost Coast - hl2.exe -game lostcoast
Half-Life: Source - hl2.exe -game hl1
Half-Life Deathmatch: Source & Half-Life 2 Deathmatch won't load maps ("CD key authentication invalid for internet servers").
11 1 111 11 1 1 1 1 1 11 1 1 111 1 111 1 1 1 1 111
Reply 19 of 30, by boxpressed
Firtasik wrote:
The latest version of Half-Life 2 can be launched without Steam. […]
That's cool. I just played about five minutes this way. Has HL2 been this way for a while, or did it happen recently?
Now, it seems as though you can "freeze" a version in time to play offline, which will safeguard against any incompatibilities in the future. Just like the old days. I don't really play multiplayer, so the Deathmatch problems aren't a loss.
