First post, by Davros
Basically had to format c: drive and re install windows lost all the registry settings
So if you have it installed could you post your registry entries (obviously XXX out you cd key if its stored there)
thanks...
Reply 2 of 10, by Davros
The problem i have is I select new game and it just jumps back to the main menu (even if i type map borg1 in the console)
the game used to work fine
Reply 6 of 10, by leileilol
It's pretty clear you're using a v1.2 client with the v1.1 game module (which should read April 10 2001 under the gamename: baseEF part). Patch up to 1.2 to fix this version conflict.
long live PCem
Reply 7 of 10, by Davros
There is a patch 1.2 readme in the game folder which makes me think I have patched it
cant reinstall the patch it thinks the game isnt installed
also the readme says
"Please note that that after applying 1.2 patch, it will update the HoloMatch code to 1.2, while Single Player will be upgraded to 1.1. If you had previously applied the 1.1 patch before installing the 1.2 patch, you will still see the Single Player version reporting as 1.1. This is completely normal."
