First post, by autoexecdotbat
hello,
I am curious, are there any text to wav converters available for dos, windows 3.1, or windows95? I'm working on a series for my new childrens channel super tottler land and was going to create the opening sequence under one of those OS's just for the heck of it. I have my dos box already set up so I can easily transfer files between the dos/windows machine and my actual computer, which is good because I was going to start most of the series outside dosbox.
Could anyone find me a text to wav converter for either dos, win3.1 or win95?
to win the game you must defeat coppa!
http://chng.it/DNc2L8LvLJ
Reply 1 of 12, by Lo Wang
The concept of text to wav doesn't make any sense without a clearly defined context.
. Are you looking for an application that will put a wav header on a ascii file so you can hear the kind of noise it'd make?
. Are you looking for a good ole' audio compiler?
. Are you looking for a text-to-speech application like "Talk It!" from Microsoft Plus! for Kids that also happens to have a wav output?
"That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved" - Romans 10:9
Reply 2 of 12, by autoexecdotbat
basicly what I'm looking for is something that is a tts program that can output to wav files. there are several such programs for current versions of windows, but finding one that works under dos, win 3.1 or win95 has been a bitch. In my google searching I didn't find anything, anything I probably found led to a dead link or something worse.
Reply 3 of 12, by Lo Wang
http://www.bytecool.com/textsnd.htm
Reply 4 of 12, by autoexecdotbat
thanks, I didn't think that program was available anymore, it hasn't been updated since 2002 I think and it never got sapi5 support. that's ok here because sapi5 doesn't work in win95 and there are some older synths that only ever supported sapi4, such as text assist 2.x (not related to the creative labs program of the same name, apart from being included with newer sound blaster cards).
Reply 6 of 12, by autoexecdotbat
OK, I did manage to find some tts programs, but they didn't have the ability to convert to wav as far as I know. then again, the age of some of those shareware cds ment that the guys responsible for those cds had to conform to the 8.3 filename limit.
Reply 10 of 12, by autoexecdotbat
i'm talking about converting text to an audio file. text sound and cool speech both do that, but i was asking about other text to audio file programs for older versions of windows or for dos.
Reply 11 of 12, by Lo Wang
Speakanoia: http://web.archive.org/web/20020804022040/htt … om/home/?id=1.4
Original yet working download for older version: http://web.archive.org/web/20020804175359/htt … iasetup-1.0.exe
Mirrored download for newest version (100% clean): http://www.geekstogo.com/forum/files/file/446-speakonia/
Free registration code provided by the very authors of the application: http://www.cfs-technologies.com/home/
