First post, by candle_86
So anyone tried to get BFME II running on windows 10, it works on 7, 8 and 8.1 but not on 10. It simply refuses to load, and no patch so far has fixed it. Right now I run it on my retrobox but an Athlon XP and FX 5900 are a little underpowered for it.
Reply 1 of 2, by teleguy
From what I can find online the game uses safedisc. Microsoft dropped support for Safedisc and Securom on Windows 10 so the only way to run such games is using a crack.
https://www.rockpapershotgun.com/2015/08/17/w … sc-securom-drm/
Reply 2 of 2, by ZellSF
Always consult the PCGamingWiki.
In addition to what that says, teleguy is probably right. That said as the article he links to writes, using a crack is not the only way (and not always possible). You can also self sign the Windows 8 version of the driver and use it in Windows 10 test mode.
I've tested and the game runs fine on Windows 10.
