First post, by Azurex
As the title says!
The game is installed on my Windows 10, 64-bit machine. I have a GTX 970, if that helps any.
When I launch the game via the launcher, or any of the .exe files, absolutely nothing happens. Nothing launches or anything. All exe's are running as administrator, and not under any compatibility modes, although I have tried a few and none of them seem to work.
Does anybody have any ideas? I've tried reinstalling, but that didn't help any.
Reply 2 of 9, by Azurex
Ah, it launches now. But now it launches in the lowest possible settings, and no matter what tweaking I do, it never saves.
Also, the Steam overlay won't work.
Any suggestions?
EDIT: Nevermind. Since the .exe I used was technically for the European release, it created a new folder in My Documents called 'SEGA Rally' and the configs were being saved to SEGA Rally Revo. After moving the config file to the new one, it works.
Still unable to get the Steam overlay working, however.
Reply 3 of 9, by BuckoA51
Don't run it as admin if you want to use overlays (that means you have to run the overlays as admin too).
Evolve has the game listed as working with overlay https://www.evolvehq.com/games/2543
Since that supports Steam too you could try that.
play-old-pc-games.com
