First post, by Elia1995
Hi, I have this odd issue with some games that use CD music that do not seem to work in Windows 98.
Obviously I plugged in the audio cable that goes from the CD drive to the audio card (as always, the Sound Blaster PCI128 CT4750), I can get CD music to work just fine under XP, but in Windows 98 it doesn't work at all.
When I launch Cold Shadow, I can hear all the sound effects minus the music due to this issue.
The thing that I do not understand is: same drivers, why does it work under XP and not under Windows 98 ? (Thus the audio cable is connected correctly)
I should've opened this thread in Marvin, perhaps, but since it's just Cold Shadow, among my games, that uses CD music, I decided to aim it to that game directly.
(I cannot play the game under XP due to the "missing kernel32.dll" error, even though I copied it from 98, now I can't boot into XP because it's missing hal.dll 🤣 but the CD music works fine and I tested it with some audio CDs)
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
Reply 2 of 16, by Elia1995
I need the music CD to work on 98, not on XP.
On XP it works just fine, except I can't boot it anymore due to the missing hal.dll problem (I'll eventually just reinstall XP for the 26th time)
Reply 3 of 16, by teleguy
XP doesn't need a separate cable. It can play CD audio over the IDE interface.
If you turn this off in device manager, music will probably stop working in XP too.
Reply 4 of 16, by Elia1995
It's greyed out...
The cable is properly connected and the letter drive is correct.
Reply 5 of 16, by teleguy
That's from Win 98, right? Win 98 doesn't have that option. AFAIK it was introduced with Win 98 SE.
What I meant with my post is that the fact that music works on XP doesn't prove that everything is ok with the audio cable.
EDIT: So you have 98 SE?
Reply 6 of 16, by Elia1995
Yes, it's Windows 98 SE with the Unofficial Service Pack 3.
Reply 8 of 16, by Elia1995
The same audio cable works flawless in my DOS computer with the CT3670...
The CT4750 has three slots for this cable, I plugged it in the middle one which says "CD IN"
Reply 9 of 16, by Jorpho
Are you sure you're using the WDM drivers and not the VxD drivers? What makes you think you have the "same drivers" in XP and 98?
You should also probably check the CD volume. Can you get CD music from any other program in Windows 98? The Windows 98 CD player is a good test. As noted above, Windows XP will function independently of the cable in question.
Do you have multiple CD drives, or a virtual Daemon Tools drive? The game may be looking for the music on the wrong drive letter. I think this may also happen if you have network drives with a lower letter than your CD drive.
Reply 10 of 16, by Elia1995
I only have one physical DVD drive and a virtual one with MagicISO on both 98 and XP (I also have the virtual drive here on 7 aswell, but that doesn't really matter as CD audio works differently with SATA drives).
I have no idea what that WDM and VxD drivers actually mean, I just installed them from my sound card's CD on both systems 🤣
CD music doesn't work at all here on 98, but it indeed does on XP.
There doesn't seem to be an issue with the audio cable because as I said earlier, the exact same cable works fine with the CT3670 on the DOS PC (tested with Rayman).
I also noticed that on Windows 98 "Creative PlayCenter" just crashes with an error saying that it can't find PLAYSVR.DLL.
PlayCenter is the software I also used on XP to try my other audio CDs and it worked fine, it even ejected the CD.
Reply 11 of 16, by Jorpho
Okay, so what if you disable the virtual drive?
Well, that hardly means they're the "same drivers", I should say.
WDM drivers may be needed to enable that digital playback option. If your sound card installer did not directly provide an option to use WDM drivers, then you should be able to download them from the Creative website.
That is almost certainly an unrelated problem.
Reply 12 of 16, by Elia1995
I just got it working not even knowing how.
I just went and reinstalled the sound drivers once again, I rebooted and changed the drive letter in that CD music window from E: to G: (my virtual drive), applied and then from G: to E: back again, launched Cold Shadow and the music worked...
that digital CD music thing is still greyed out, but the music works, I guess with that audio cable.
It's very unstable though, it worked, then I tried to launch the game again and it was without music again, after I restart there's the music the first time I launch the game and from the second time onward isn't there anymore and I have to reboot to get it back.... it's quite annoying, I hope there's now a fix for that aswell :\
Ah, I almost forgot, after I reinstalled the drivers, Creative PlayCenter works aswell... so if someone got that PLAYSVR.DLL error, just reinstall the drivers 🤣
Reply 13 of 16, by Jorpho
Many old CD-ROM games did not expect systems to have more than one CD-ROM drive. When you get no music, it is probably because the game is trying to play music from the wrong drive. (I'm not entirely sure what the drive letter setting in Multimedia Properties is supposed to do.) I think there's some discussion of how this happens at http://www.play-old-pc-games.com/2015/02/10/w … shadows-empire/ (as well as potentially a means of patching the program), but from what you describe you may be able to reliably solve the problem by setting your virtual drive to drive E and setting your CD-ROM drive to a lower drive letter.
Reply 14 of 16, by Elia1995
Since the standard, default cd-rom drive should be "D:", and "D:" is used by the second hardisk, I should also try to move the second HDD's letter to E: and the DVD-rom's to D:, maybe most old games look under D: by default.
I think it's supposed to set the default letter drive from which all games should look for in order to play CD music.
Reply 15 of 16, by Jorpho
Elia1995 wrote:
Since the standard, default cd-rom drive should be "D:" <snip> maybe most old games look under D: by default.
No, they don't. There was never any kind of standard, unofficial or otherwise, that assumed the CD-ROM drive would be "D:". (I'm sure there's probably at least one very badly-coded game that assumes the CD-ROM drive must be D:, but you can find bad code that assumes just about anything.) It is far more common for games to look at the last assigned drive letter, or alternatively to look in the first drive letter that is not assigned to a hard drive.
Reply 16 of 16, by Elia1995
Well, in every PC I had and have with only 1 hardisk and CD-ROM drive, the letter of such drive is always D:
