First post, by filipetolhuizen
Is there any possible way to replace the incompatibility message on any Win 64 bits when you try to run a 16 bits program with an emulation layer or a minimalistic virtual machine upon launching the desired application? I googled for that a lot but found nothing.
Reply 1 of 11, by Jorpho
"Any possible way" ? I suppose if you really wanted to, you could associate all .exe files with a special launcher that will first check if the program is 16-bit and otherwise launch the .exe normally. But I don't know if such a launcher already exists.
Reply 2 of 11, by filipetolhuizen
You got my point. I suppose the message is due to another program which runs when you try to run 16 bits applications. If so, replacing this program with wowexec or something else like WINE could be possible?
Reply 3 of 11, by collector
WOW is dependent on NTVDM, so you would need to deal with that first. That said, there is this: NTVDM on windows 10 x64
Reply 4 of 11, by filipetolhuizen
Now that's some interesting news. Perhaps there might be some hope after all.
Reply 5 of 11, by Jorpho
A separate program? I expect it's some internal Windows thing buried in the kernel.
A quick Google search turns up a page in Windows Internals:
https://books.google.ca/books?id=w65CAwAAQBAJ … 20ntvdm&f=false
You could go and try to patch the kernel or insert some sort of hook, I suppose, but in the end it would probably be easier (and safer) just to make a separate launcher for starting every .exe file.
There have been threads here before about running WINE on Windows; at this point I doubt it's ever going to happen (unless it's something like WINE running in Linux running in DOSBox). Besides, WINE's ability to run 16-bit Windows code relies on some unique trickery exclusive to the Linux kernel, and even those tricks are starting to get phased out (or so I understand).
Reply 6 of 11, by collector
The link doesn't work for me. How was Vlad detecting DOS EXEs for VDMS Launchpad? It was never an option for NE or PE executables. Could the same thing be extended to include NEs?
Reply 7 of 11, by Jorpho
Still works here. It's just one of the Google Books search results for <how does windows decide whether to run ntvdm>.
Reply 8 of 11, by Stiletto
Can't see it either. I guess it's blocked for Americans?
do the Fandango!" - Queen
Stiletto
Reply 11 of 11, by Stiletto
collector wrote:
Changing the ca domain to com makes it work.
D'oh! I shoulda thought of that. 😢
Stiletto
