Reply 20 of 23, by filipetolhuizen
- Oldbie
Something's wrong with Aladdin.
wrote:Something's wrong with Aladdin.
Yep
At least it's a lot easier to play like that. Did you fiddle with the options?
wrote:At least it's a lot easier to play like that. Did you fiddle with the options?
If you do run it in its messed up FullScreen mode or in the default window option, it does run a bit faster.
Though I'm probably gonna be installing the DOS Version of Aladdin once I uninstall the Windows Port since the DOS version runs alot better.
