Lion King
Reply 23 of 23, by Dakkiller
filipetolhuizen wrote:
At least it's a lot easier to play like that. Did you fiddle with the options?
If you do run it in its messed up FullScreen mode or in the default window option, it does run a bit faster.
Though I'm probably gonna be installing the DOS Version of Aladdin once I uninstall the Windows Port since the DOS version runs alot better.
