First post, by UCyborg
- Oldbie
I've recently assembled a brand new patch for classic Max Payne games, solving one of the biggest technical issues with those games, in some cases preventing them from starting-up on modern systems without hacky workarounds like starting the game with affinity set to single core or worse, running them in compatibility modes. I'll probably upload the patch to PC Gaming Wiki as well. Straight from the ReadMe:
This patch is intended to solve issues related to game engine initializing Direct3D inside DllMain, which most notably causes the game to hang during startup with certain combinations of graphics hardware and drivers. Additionally, it is impossible to run the game through dgVoodoo Direct3D 8 to 11 wrapper, because Direct3D 11 runtime refuses to initialize from DllMain to prevent lockups.
The patch will solve above mentioned issues and possibly other problems that might be related to Direct3D initialization inside DllMain by delaying actual initialization to the point when execution flow returns from LoadLibrary API, therefore preventing any sort of lockup that would occur otherwise.
No compatibility modes should be applied to game executables, as they usually create more problems than they solve. Starting the game with affinity set to single core also isn't required anymore and will only serve to slow the game down a little.
Files in this archive are intended to use with latest version of games, which are:
Max Payne v1.05
Max Payne 2 v1.01
If you have Steam version of games, you should already have latest versions, otherwise, they must be updated with appropriate official patches before applying this patch.
To install, simply extract contents of each game's folder into your own, overwriting original files.
wrote:A man can be himself only so long as he is alone; and if he does not love solitude, he will not love freedom; for it is only when he is alone that he is really free.
		 SCAR 18 G834JY: i9-13980HX,  32GB DDR5@5600,  4090 laptop 256 bit 16GB, 2560x1600 16:10 G-Sync, NVMe 6GB/s, 8BitDo Arcade Stick, EasySMX X10 controller, ROG Strix Carry Mouse.
