First post, by Zeether
I've noticed someone has been able to get the first HG game running on modern Windows with some tweaks via Youtube, but every single time I start the game it gives me two errors:
I have tried the game on PCem and it worked fine, but I'm wondering what exactly is causing this issue.
Reply 2 of 4, by Zeether
The person who got it working installed the 1.1 patch, which I tried but it still threw up errors. They used DXWnd too to force window mode but I'm guessing that would assume that the game runs properly first.
Reply 3 of 4, by ZellSF
You can place stuff in quotes when you Google and it will find that exact match of words. So what do you get when you combine "Heavy Gear" and "one or more dlls" in a Google search box? A suggestion to check your DEP settings.
