First post, by stranno
- Member
This is a weird one.
I have tried Miami Powerboat Racer (Miami Speedboat Racer in EU), a cheap clone between Rapid Racer and Wave Race 64 with power-ups, and music works fine with _inmm, but sounds do not work. They are just WAV files , PCM 22KHz Mono 16bits. There's no fancy sound API or weird codec, just WAV files.
But it doesnt matter what volume you set in options (both ingame options and launcher options) it doesnt sound anything but the music.
Any idea? The game is bundled with indeo codec but there are just two videos and both of them are just MPEG1 files. Most of the redist are not needed at all.
Direct3D 8 game. dgVoodoo not needed, it works out of the box in Windows 10 64-bit and you can set the resolution to whatever value you want.
