How to create standalone Windows ACT compat. databases?
Getting old Windows games working.
Postby Expack3 » 2017-11-07 @ 19:26
I've found an expansion to a game called Elona, itself called Elona+, which has a RTD error on Windows 10 with HiDPI monitors...like it's trying to read pixels which, due to screen magnification, aren't at the same memory position they'd be at if the monitor was using a 1:1 pixel ratio. That's not a problem - it's the kind of game where forcing "System (Enhanced)" actually works.
Now, with Windows 10 version 1709 (aka the Fall Creators Update), it has RTD issues with MP3 playback - rather important for a user with average tech literacy who wants something which sounds decent. Thankfully, I've been able to almost fix the game by forcing it to use WaveOut via a custom compatibility database built with the Windows Application Compatibility Toolkit (ACT). I'd like to distribute this database for testing as well as feedback on how to fix the error I get on exiting the program (yet more "can't read from memory" issues).
Question is, how do I distribute a custom compatibility database such that someone without the Windows ACT can install it?
Expack3
Re: How to create standalone Windows ACT compat. databases?
Postby teleguy » 2017-11-07 @ 19:47
Distribute the sdb file you created alongside a batch file with this content
Code: Select all
sdbinst.exe "%~dp0Filename.sdb"
pause
where "Filename" is the name of the sdb file. The database can then be installed by running the batch file.
(sdbinst.exe is included with Windows.)
Example:
viewtopic.php?f=8&t=33579&p=579129#p579129
Edit:
https://github.com/MicrosoftDocs/window ... ne-tool.md
teleguy
Postby Davros » 2017-11-07 @ 22:14
what are RTD issues ?
User avatar
Davros
Postby Expack3 » 2017-11-08 @ 00:25
Davros wrote:what are RTD issues ?
"Return to Desktop", aka CTD/Crash to Desktop (should've just said the latter)
Expack3
Return to Windows
Who is online
Users browsing this forum: No registered users and 4 guests
