First post, by MagicPink
I just managed to find an old copy of this. How well does it work in Windows XP if at all?
I can't talk for XP, but I installed and ran it in 2000 with absolutely no problems if that's any help.
Well, apart from the fact that I suck at it...
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
Well, no it's not a HUGE help. I don't know much about either OS except that XP seems to hate all my old games.
When it runs on W2000, it will very probably run in WXP as well.
Mirek
YAY 🤣
Thanks, folks!
Surprise!
It doesn't work in XP.
It has the same problem that apparently the other WIndows OSs had: it freezes when you click install. They say on lucasarts that to get it to work I need to make a boot disk but they only give instructions for doing it in 95 and 98:
edit: Or I could just use Compatibility mode set to Windows 2000.
If they're telling you to make a boot disk for 95/98, then it's probably a DOS-friendly game, not a Windows-friendly game. Typically, you will have trouble running DOS games under NT/2000/XP.
That said, you might give DOSBox a try. I was recommended it by the community here, and it's run a few DOS games for me without any problem on XP Pro. Might just be the way to get your game running again...
