First post, by acb764se
Hi there.......I need help with a piece of software from Microsoft.
My dosbox installation of Windows 3.1 went very smoothly (congratulations for a swell piece of code! 😀 all seems to be working fine,
except this particular item.
What happens is, when the command "imgmount d: /tmp/MSBeethoven.cue -t iso -fs iso" in the conf file is issued I get this:
MSCDEX: Failure: File is either no iso/cue image or contains errors.
and I get no d: drive. The .cue file appears below, and i can't see anything wrong with it, execpt the disc seems to be a bit longer than most.
Note that another very similar program called "Microsoft Mozart" installs and runs w/o a glitch.
Any hint why is this? Thank you!
PS the host is Linux CENTOS 7 and .cue/.bin files where obtained with Brasero.
FILE "/tmp/MSBeethoven.bin" BINARY
TRACK 01 MODE1/2352
INDEX 01 00:00:00
TRACK 02 AUDIO
PREGAP 00:02:00
INDEX 01 01:07:08
TRACK 03 AUDIO
INDEX 00 17:44:18
INDEX 01 17:44:25
TRACK 04 AUDIO
INDEX 00 27:54:02
INDEX 01 27:54:12
TRACK 05 AUDIO
INDEX 00 43:45:43
INDEX 01 43:45:47
TRACK 06 AUDIO
INDEX 00 69:29:65
INDEX 01 69:29:69
